Old November 9th, 2007, 12:00
big black xj's Avatar
big black xj big black xj is offline
anyone know where i can get ceramic pads for the 89 xj?
i have looked everywhere online and found http://www.autopartswarehouse.com/ba...tem_id=5709260
It says those pads fit 1983-1991, but im almost positive that the pad got a tiny bit larger in 1990.
My only other option it to do a newer set up from the knuckles out.
Knuckles
Unit bearings
Calipers
and then Ceramic pads...... PRICEY.
Old November 9th, 2007, 15:58
bjoehandley's Avatar
bjoehandley bjoehandley is offline
Re: anyone know where i can get ceramic pads for the 89 xj?
I wouldn't waste my money on ceramic pads, I've never had much luck with them in the braking department, just get some Raybestos semi-metallics and you should be good.
Old November 9th, 2007, 16:32
jk333's Avatar
jk333 jk333 is offline
i think when they say 83-91, they mean the full size cherokee's in that year. i found a set of ceramics for my 87 at Autozone. that's really the only place that i could find them. i had a mishap where one store gave me the pads for the fullsize Cherokee.
Old November 10th, 2007, 00:56
darjevon's Avatar
darjevon darjevon is offline
Ceramic pads aren't "soft" like semimetallics are - if you get sand on your brakes, the ceramics will ram it into the rotor and this is not good... semimetallics, the sand will get pressed into the pad.
Old November 10th, 2007, 07:45
langer1's Avatar
langer1 langer1 is offline
Ceramic pads will wear the the rotors about as fast as the pads, ceramic pads on stock cast iron rotors is not a good idea.
IF you want to replace rotors and pads every 20k miles go for it.
ceramic heat barrier forcefed Modified Tech Discussion 6 July 30th, 2007 16:23
New brakes/ceramic pads Red97XJ Modified Tech Discussion 4 October 22nd, 2006 22:27
Anyone run ceramic brake pads? Atl XJ OEM Tech Discussion 13 September 24th, 2006 18:26
Semi Metallic vs Ceramic bjoehandley Modified Tech Discussion 4 June 21st, 2006 13:21
brakes squeal with new ceramic pads!!??? olivedrabcj7 OEM Tech Discussion 11 July 21st, 2005 06:18
