Old October 23rd, 2007, 07:51
ahm's Avatar
ahm ahm is offline
P1391, What the ?
Trouble code P1391 - Loss of CMK or CKP ??
Does anybody know what this is?
The truck will run fine until you rev engine up to 2000rpm the engine will drop to 200rpm and giving it throttle wont do anything.
Old October 23rd, 2007, 10:19
MapleDitch MapleDitch is offline
Re: P1391, What the ?
CKP is Chrysler's acronym for CPS or Crank Position Sensor.
Old October 23rd, 2007, 15:49
ahm's Avatar
ahm ahm is offline
Thank you, thats what I was thinking but wasnt sure.
The XJ runs good sometimes, the loses all power till i turn off & restart.
Old October 23rd, 2007, 16:05
Timber's Avatar
Timber Timber is offline
Sorry about the way these look, but I couldn't copy and paste them so I took screen captures.
Old October 23rd, 2007, 17:44
ahm's Avatar
ahm ahm is offline
This info is great, thank you very much.
I just went out & purchased 2nd CPS($106) to ind out thats not the problem. W/this info i can do more testing and less spending.
thank you
Old October 24th, 2007, 08:51
Timber's Avatar
No problem. Post up how things turn out.
Old October 24th, 2007, 11:24
ahm's Avatar
ahm ahm is offline
OK, CMP(coil pick up) came up bad, I replaced and now the truck wont start, kicks over sometimes but wont start.
Old October 24th, 2007, 14:33
Timber's Avatar
This is copied from my 1999 F.S.M. I don't know if this will help or not (hope so).
"ENGINE START-UP MODE
This is an Open Loop mode. The following actions occur when the starter motor is engaged. The powertrain control module (PCM) receives inputs from:
² Battery voltage
² Engine coolant temperature sensor
² Crankshaft position sensor
² Intake manifold air temperature sensor
² Manifold absolute pressure (MAP) sensor
² Throttle position sensor (TPS)
² Camshaft position sensor signal
The PCM monitors the crankshaft position sensor. If the PCM does not receive a crankshaft position sensor signal within 3 seconds of cranking the
engine, it will shut down the fuel injection system. The fuel pump is activated by the PCM through the fuel pump relay. Voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM will then control the injection sequence and injector pulse width by turning the ground circuit to each individual injector on and off. The PCM determines the proper ignition timing according to input received from the crankshaft position
sensor."
Old October 25th, 2007, 13:23
ahm's Avatar
ahm ahm is offline
Thanks for info,
The fuel pump is still running, it seems to be pumping fuel like its running, strong smell of gas. Wont start. I couldnt locate another coil pickup(CPS), i think my new one is bad.
Old October 26th, 2007, 08:41
ahm's Avatar
ahm ahm is offline
Thanks Timber,
I brought XJ to Jeep, I gave them all I did on paper. Hopefully they find it.
Old October 26th, 2007, 10:11
Timber's Avatar
Good luck.
Old October 28th, 2007, 07:44
ahm's Avatar
ahm ahm is offline
I Need it.
Well Jeep looked at for 2 hrs and have no idea what it could be. They told me they can cont. to look at but it will get very expensive($98hr). I picked it up and i'm going to check wiring, Jeep said the sensors(Cam & Crank) are good and the timing was good.
Start there first.
Old November 9th, 2007, 06:12
Frank Z's Avatar
Frank Z Frank Z is offline
Any luck finding the problem? I've getting the same code and have also replaced the Crank Position Sensor.
Old November 9th, 2007, 19:33
Ricker's Avatar
Ricker Ricker is offline
Similar problem here. Both sensors are ok. Loss of signal above 2K. Has something to do with the two signals being out of sync. I only get a CEL, no shutdown.
I will post when I discover more.
Rick......
Old November 10th, 2007, 07:38
Timber's Avatar
In thinking more about this, and please note that I'm just beginning to learn about engines and transmissions, is it possible that a cracked flexplate on an auto. or a bad flywheel on a manual could cause the CKP to send a bad signal?
