Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old August 30th, 2007, 11:19
JONNYD JONNYD is offline
Mopar Roller Rockers?
Summitracing.com part #DCC-4529885. These are mopar performance roller-rockers for a 4.0 at what seems to be a very resonable price. Is this the real deal?
Old August 30th, 2007, 11:55
streetpirate's Avatar
streetpirate streetpirate is offline
Re: Mopar Roller Rockers?
that is the real deal, but thats only the price for a pair, plan on paying that 6 times.
off of mopartsracing.com
Roller Rocker Arm Set — Single Cylinder
This single cylinder Roller Rocker Arm Set for Jeep vehicles includes one cylinder set of two rockers, two support stands, rocker shaft, and screws. Extruded, anodized aluminum rockers. Can be used with hydraulic, mechanical or roller cams. Roller tip and center pivot bearing reduce internal friction. Provides exact geometry and 1.6:1 ratio. Adjustable, oil-through-pushrod style. 2.5L and 4.0L engines require aftermarket spacer for valve cover clearance. P4529885 Roller Rocker Arm Set — Single Cylinder (2.5L, 4.0L, and 4.2L Jeep Engines) 149.95
Originally Posted by kastein
I'd have to say a hand sledge or an angle grinder is the most useful tool though. You can do anything from brutalize your fingers to breaking everything around the thing you're trying to hit/cut with them.
Old August 30th, 2007, 13:19
Yeah, I am retarded and can't read. Sorry. $899.70 is not a good deal...
Old August 30th, 2007, 14:20
FoMoCo FoMoCo is offline
haha, don't worry about it man, I thought the same thing the first time I saw those...I mean WTF, who sells rockers by teh pair?
Old August 30th, 2007, 15:45
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
The Yella Terra YT6627 roller rockers are much cheaper and fit under the stock valve cover. You can buy them from Quadratec.
Old August 30th, 2007, 18:48
Hellbent's Avatar
Hellbent Hellbent is offline
i saw those, the price is not too bad. do you think those would be of any real benefit on an otherwise stock head?
Old August 31st, 2007, 09:14
very little, but the reduced weight and friction in the valvetrain is always a good thing. as with all mods, it needs to be coupled with other mods to see its potential.
Old August 31st, 2007, 13:11
Hellbent's Avatar
that's more or less what i figured. thanks.
Rate This Thread:
roller rockers killer98xjsport Modified Tech Discussion 12 July 10th, 2007 23:27
roller rockers? Justpunchit Modified Tech Discussion 16 March 13th, 2006 04:23
knew I'd seen them somewhere--Mopar roller rockers HoratioTheJeep Jeep Street and Performance 6 February 26th, 2005 04:20
roller rockers Sephrion Jeep Street and Performance 22 October 2nd, 2004 00:27
Roller Rockers CW Modified Tech Discussion 0 December 10th, 2003 17:18
