Old August 10th, 2007, 10:45
XpedientJ's Avatar
XpedientJ XpedientJ is offline
Coolant Filter....
I have a trans-filter housing, opting for this as a means to plumb in the trans-temp gauge sender unit....and, am wondering if anyone can advise, with technical and empirical certainly, if a standard oil filter (such as a Wix 51515 or K&N HP-3001) is suitable for coolant filtration...
Thanks much.
Old August 10th, 2007, 12:28
Hellbent's Avatar
Hellbent Hellbent is offline
Re: Coolant Filter....
i don't believe so, but i can't remember exactly why now, something about the media type. however, wix does make a specific screw on coolant filter for hd diesel trucks and such. it's listed in the back of any wix filter book. try your local carquest maybe?
Old August 10th, 2007, 22:16
XpedientJ's Avatar
I was, rather obviously, thinking of two things at the same time when making this post....
My question is re suitability of oil filters for trans fluid filtration!
Coolant ddeadserious OEM Tech Discussion 1 May 13th, 2007 15:49
Coolant in Air Box critik OEM Tech Discussion 3 June 23rd, 2006 15:55
Coolant on my air filter Poppinblock OEM Tech Discussion 1 April 11th, 2006 23:41
Coolant in Oil bajacalal OEM Tech Discussion 2 September 19th, 2005 11:43
how much coolant does an xj need? montysbxj OEM Tech Discussion 4 July 17th, 2005 21:35
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
