Old July 19th, 2007, 13:31
badgator badgator is offline
Thumbs up The XJ Mercedes turbo diesel conversion forum
I bought a 85 MB 300sd 6 weeks ago 125 hp/170 # torgue(which I love driving, gets 25-30 mpg 3800? lbs) , now my XJ runs like crap I want to install a mid 80's 5 cylinder MB turbo diesel in my XJ. I have researched this for more than a year, as there are a couple running examples BUT nobody sells an adapter or kit. I found another MB turbo running good for cheap - donor. I also built a WVO centrifuge to burn WVO in my diesel(s)!!!
Old July 19th, 2007, 13:37
Re: The XJ Mercedes turbo diesel conversion forum
I have a jeep 4.0 spacer plate to use as a bellhousing bolt pattern. So far.
Old July 19th, 2007, 14:05
casm's Avatar
casm casm is offline
I seem to recall that there was an MJ out there with a Mercedes 300TD in it. However, the MJ was 2WD as the oil pan on the Mercedes engine wouldn't clear the D30 found in a 4WD model. IIRC, the MJ in question was destroyed in Katrina but some searching should turn it up.
Old July 19th, 2007, 16:03
motorcityxj motorcityxj is offline
had it bookmarked.
I am doing all sorts of diesel swaps in my head
http://www.naxja.org/forum/showthread.php?t=57574
if your into the benzo diesels here is a cj8 with a merc 2.9 http://www.cookbros.com/mbz.html
ask around on here and see if they are of any help http://messages.jeep2diesel.org/
Old July 19th, 2007, 16:24
casm's Avatar
Originally Posted by motorcityxj
had it bookmarked.
Awesome. I always liked the job he did on that, but sort of just filed it under 'neat' and forgot about it since it's 2WD. A shame, too, because there's no shortage of those 300TDs around here and they go forever if looked after properly. Power output's not too bad for an older diesel, either.
Me too The 2.8CRD coupled to the 545RFE looks like the best but most expensive bet: given the roughly 700lbs. of weight that a KJ CRD has to carry around that an XJ doesn't, performance should be pretty cracking and a fully-optioned CRD only weighs around 60lbs. more than a 4.0.
A 4BT might also be doable, but I'd really like a more modern unit in there (not that I have anything against the 4BT).
Just mentioning the diesel engine swap matrix for the benefit of the search feature; it can be found here.
Old July 21st, 2007, 04:19
Smile Re: The XJ Mercedes turbo diesel conversion forum
My exhaust is all but done, as I already have 2 1/2" with a hooker aero muffler. Mating the turbo downpipe to the ex should be EZ as they are both on the same side.
Old July 21st, 2007, 08:47
90Blue_XJ's Avatar
90Blue_XJ 90Blue_XJ is offline
Try this link www.jeep2diesel.org may be the link you need.
Old July 22nd, 2007, 06:35
I have been researching this and other jeep/diesel conversions since at least May 06 - more likely 05 and well over 100 hours searching the internet. Decided to go with Mercedes 5 cyl turbo. For longevity and cost. Luckily my Jeep engine problems are not as bad as I thought so I can start the conversion with minimal stress - on me! A ex coworker offered me a new 3" Rough Country lift kit for $200 - needed for oil pan to front axle clearance.
Old July 22nd, 2007, 10:10
Also keeping AC/ALT/PS/Oil Cooler from Mercedes, Alternator brushes and regulator is replaced with 2 bolts on back of alt, $35? at Autozone. Uses GM AC compressor (I live in FL). PS pump even has built in filter. Oil cooler is mounted vertically next to radiator about 16" tall.
Old July 22nd, 2007, 11:20
Wink Re: The XJ Mercedes turbo diesel conversion forum
My 85 Mercedes 300sd 4 speed auto NOT overdrive, 2.88 rear end ratio - VERSUS - 89 Jeep Cherokee limited AW4 overdrive 3.55 rear end ratio (I'll keep the AW4). The MB powered XJ should be quicker (compared to a 300sd) AND get more MPG, BUT a 300sd has a lot lower drag c/e. Note - on this diesel when you kicked it down turbo lag is AT LEAST 2 seconds, before it starts spooling up, in traffic you have to kick it down way ahead, OR sit and wait!!! Once it starts getting boost pressure it builds quickly(to 10# on boost guage). This is my first TD, my 3rd turbo.
Old July 22nd, 2007, 14:27
according to that link from CASM the benzo diesel has 84 hp and 140 lb/ft of torque. Is yours painfully slow ?
My diesel swap idea is a rollover or theft recovery tj unlimited, with a mildly modded cummins 4BT1 125 hp 280 lb/ft, or the cummins isb 3.9 which is 170 hp and a whoping 420 lb/ft if i can ever find one at a half decent price!
the runner up conversion (and very very distant second place) am gonna put a vw turbo diesel in a flat fender or a suzuki samari.
Old July 23rd, 2007, 17:52
0-60 times are about 15 sec. 50 - 75+ is pretty quick. Turning left in traffic sucks as you have to plan ahead with 2-3 seconds of turbo lag. This can be adjusted out (ALDA) and boost pressure increased to get 0-60 near 10 sec. I bought a adjustable boost controller off ebay $10 2 weeks ago, but with current Jeep problems I decided holding off playing with the injector pump/ALDA and wastegate for now. 84 hp = No Turbo. 4BT would be nice but low rev limit, more vibration and a lot more weight to deal with.
Old July 23rd, 2007, 17:58
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
How about a GM 6.2L diesel?
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
Old July 23rd, 2007, 18:10
I'm guessing you could use a gm to jeep adapter which is readily available, if the 6.2 is about same size as a SBC.
Old July 23rd, 2007, 18:19
NAXJA Forum Addict
exactly what i was thinking
I had an FSJ that I was toying with the idea of a 6.2 swap, they're about the same size as an SBC, use the same mounts, so they should fit in an XJ. 6.2's are very common in the millitary surplus world, and therefore pretty cheap to obtain.
More power? Throw on the turbo kit from the 6.5L.
Bolt it up to a TH400 and you're good to go.
John V.
Mercedes Benz Diesel Engines 4xBob OEM Tech Discussion 0 January 10th, 2007 10:31
Turbo Diesel XJ ? desertjeeper SoCal Chapter 7 July 13th, 2006 10:24
turbo diesel (again) WilliesTJ Modified Tech Discussion 17 October 13th, 2004 09:50
turbo diesel XJ GTsenre OEM Tech Discussion 5 September 21st, 2003 17:33
