Old July 18th, 2007, 18:26
CustomCrawler CustomCrawler is offline
blower motor fuse
I keep putting a 25 amp into my blower motor fuse (ac/heat, in the book says blower motor though)
All it does is blow them soon as it gets connected.
My AC/Heater doesnt work at all. My heater use to work, but not it doesnt. (blowing fuses.)
Old July 18th, 2007, 19:34
MisterFubar MisterFubar is offline
Re: blower motor fuse
I'd stop putting fuses in it and start looking for the short.
Old February 19th, 2008, 11:44
sundelin sundelin is offline
Can you fix a larger picture?
Old February 19th, 2008, 11:52
Shorty's Avatar
Shorty Shorty is offline
I'd run battery + to one wire of the blower and neg- to the other and see if the blower works. I'd then try the same thing through a 25a fuse and verify it isn't drawing too much power. If the blower passes that test, I'd start looking for shorted wires.
you can work from either direction (battery through circuit to blower or blower back through circuit to battery), but make sure there is a methodical process and double check each step before you move on.
mjma's Avatar
mjma mjma is offline
See if the blower motor works on full blast?? If so, it's the blower motor resistor.
I changed mine 2x before realizing that the actual blower motor was going bad and drawing too much current, which kept blowing the resistor. Changed the blower motor, and put in another new resistor, and it's been fine ever since.
Old February 19th, 2008, 15:34
It was a short (this thread is old) but thanks.
Blower motor not working. replaced motor and resistor...Searched can you help? 99xjclassic OEM Tech Discussion 12 May 4th, 2007 22:31
A/C blower keeps blowng the fuse :( tcm glx OEM Tech Discussion 32 January 3rd, 2007 09:00
Blower keeps blowing A/C fuse tcm glx Modified Tech Discussion 4 June 19th, 2006 11:21
Blower fuse keeps blowing out truckeejeeper OEM Tech Discussion 6 January 10th, 2005 19:59
another blower motor ? jeepme OEM Tech Discussion 3 December 6th, 2004 10:22
