Old July 10th, 2007, 11:40
DanDXJ DanDXJ is offline
The Heat is On
I have a 2001 with 4.0L ,auto and A/C. No matter what the temperature setting is it blows hot air. The fan works on all speeds, the mode selector changes from floor heat to defrost to vent as desired. The A/C clutch engages and accumulator lines get cold. However, I get nothing but hot air inside. There is no heater control valve in the heater hose under the hood. The heat selector switch appears to be electronic, not a slide switch like the older XJs. Is there a way to test the switch? I assume it is not cheap from the dealer and would like to know that it is the problem before forking over the cash.
I appreciate any help you folks can give.
Old July 11th, 2007, 19:30
eddieeddieg eddieeddieg is offline
Re: The Heat is On
Sounds like the blend door motor is not operating properly.
Possible the electrical connection has come loose at the floor level.
http://z.about.com/d/autorepair/1/0/a/G/57435881.gif
Eddie
Old July 12th, 2007, 19:42
Re: The Heat is On
Thanks for the reply -- I found the blend door actuator and removed it. I can manually operate the blend door with pliers and get the temperature to change. The default mode is heat so I have to restrain the door with pliers in the cold position for the A/C to work. Now I know the blend door works, the big question is, is the actuator not working or is the contol knob/switch which controls the actuator not working. Any suggestions on testing these would be helpful.
Thanks
DanDXJ
Old July 31st, 2007, 19:37
Re: The Heat is On
I have replaced the blend door actuator(motor) and the dash heater/AC control panel. The problem still exists -- blows hot air no matter what the temperature control is set to. The temperature control and the blend door actuator are both getting power. The wiring diagram shows an interface between the temperature control and the PCM but I'm not sure how this would effect my problem. Any suggestions on what to check next would be appreciated.
Thanks
DanDXJ
Old August 2nd, 2007, 10:27
GT-UK GT-UK is offline
Re: The Heat is On
I have a 2000 2.5 with the same problem. Could someone tell me where to locate the air blend door motor? Thanks - GT-UK
Old August 2nd, 2007, 16:50
Re: The Heat is On
On a US left hand drive XJ the blend door is on the right hand passenger side of the floor console up on the bottom of the heater box next to the heater floor discharge. A sketch of it is in the link in one of the above posts. It is a black box about 3 inches by 3 inches and 3/4 of an inch thick . It is actually easy to locate. It is held in place with 3 screws and when removed allow the motor to slide off the blend door post. It has a three wire electrical connection on the back. You may have to fold the carpet back to allow a socket wrench to get access to the screws. If your XJ is right hand drive I would assume it is in a similar location in the left hand passenger side.
If I can help further let know. My problem still exists even with a new actuator(motor). After installing a new heater control and actuator the motor still does not work.
DanDXJ
Old August 3rd, 2007, 01:29
Re: The Heat is On
Thanks for the information. I'll take a look at mine and let you know if I find anything. I already checked that there was voltage to the control switch input wires and variable voltage from the switch output wire. Thanks again - GT-UK
Old July 7th, 2008, 22:35
c.kisner c.kisner is offline
Re: The Heat is On
thx Dan for the info,
my rig is an 00 4.0 auto
my a/c started doin the same exact thing. everything works w/ controls but only hot comes out. lines are cold, compressor is on, all that. but oddly enough i could not located the blend door actuator (kinda like the A-hole in the fog) have been diggin on this for a couple of weeks, in AZ we are in the triple digits w/ hot air blowing or windows down. anyways, from here i can start figuring this out. i will let you guys know how this works out.
thx for all info and help!!
Old July 17th, 2008, 20:54
Re: The Heat is On
so, i got the blend door actuator off, i was able to pull the gear out of it. using the rod from the actuator i have been able to physically move the blend door from hot to cold, and cold comes out!!!
question for you guys is how to i determine if the controls are bad or the actuator is bad? any way to test either of them?
thx in advance, Cade
Old November 13th, 2009, 17:01
Mike H.'s Avatar
Mike H. Mike H. is offline
Re: The Heat is On
long shot, but, any known fix for this issue?
Old November 13th, 2009, 17:35
joe_peters joe_peters is offline
Re: The Heat is On
Always helpful to post year and any other pertinent info.
Also, you have drug up two posts on the same issue, best to stick with one thread at a time.
Old November 13th, 2009, 17:46
dagr8tim's Avatar
dagr8tim dagr8tim is offline
Re: The Heat is On
On mine, the cable just came off. 30 seconds to put it back on.
Old November 13th, 2009, 17:49
Mike H.'s Avatar
Re: The Heat is On
actually, one is on mixed heat(other thread), and this is on nothing but heat... I thought they were 2 different issues, but if not that is good news.
Jeep is a 1997 sport, 4.0 5spd... it does have a/c.
as of now...
I went out and actually "looked" right at the thing in the passenger side footwell that controls the blend door (searching here me there...)
When I adjust the cable by hand, I can contol heat, and switch to a/c... by simply moving the cable to and fro... and it definately will run the a/c.
When I set the cable by hand so it blows cold air... the dial moves to the cold position... and by turning the dial it moves the cable back to hot...
But, once turned to hot, the dial will not move the cable back to cold, the dial just spins freely...
So, how do you go about removing the "dial" and installing one that will "hold/move" the cable...
So if I can figure that out I have my "heat only" deal figured...
But, I still would like some help on why heat blows out the drivers side footwell when the AC/heat system is turned off.
Old November 13th, 2009, 17:50
Mike H.'s Avatar
Re: The Heat is On
Cable is attached at the "thing in the footwell"...
Any help on making it be "on" at the dial would be very welcome.
Old November 13th, 2009, 17:52
dagr8tim's Avatar
Re: The Heat is On
I've got most of the dash out of my parts jeep (98 Sport). I'll take a look tomorrow and snap some pics.
Heat maine96xj OEM Tech Discussion 6 November 26th, 2006 20:11
no heat delverde OEM Tech Discussion 3 November 13th, 2006 09:15
no heat.... goin4wheelin OEM Tech Discussion 15 January 30th, 2005 22:41
No Heat! Wayne Sihler OEM Tech Discussion 4 January 20th, 2004 06:22
