Old June 21st, 2007, 07:57
markaboo929's Avatar
markaboo929 markaboo929 is offline
Renix 1988 hi idle at start up
hey I am wondering if / there is anything i can do anout the hi hidle start up.I keep having the IAC motor stay stuck when it starts up cause the friigin french renix crap is designed to retract the freakin thing all the way IN on start up and it starts at 3000 rpm hangs then comes down-hell sometimes it doesnt go back to idle and it sux balls!!!!!!! any ideas why it does this and what is there to fix it?all ready did tps and iac and tps adjusted correctly.....any takes?........... I have the repair slips fro moriginal owner and he has ha dit looked at a gazzillion times.It has had different pcm,tps,crank sensot,map sensor....blaa blaa except fo new coolant and air temp sensors can this cause this intermitent hi idle start up???????
Old June 21st, 2007, 08:04
old_man's Avatar
old_man old_man is online now
Re: Renix 1988 hi idle at start up
More than likely your power latch relay is hosed. It keeps the power to the computer for a few seconds after you turn off the key so that the computer can reset the IAC and be ready for starting the next time.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old June 21st, 2007, 08:55
thanx OM I already tried it with a different relay --- same thing,funny its intermitent .... if i leave it out it starts at a low idle then picks up and idles great around 800 rpm,with it in it idles around 1000 - 1200-- SOMETIMES.........dunno I wish they didnt design it so gay......if the pcm knows where to set it while its runnin what in the hell were the frogs thinkin????
Old June 21st, 2007, 09:24
old_man's Avatar
Hey no bad mouthing Renix. Some of us like them. It's like being married, once you find out what the quirks are, you can learn to manage.
Loveland, Colorado
Old June 21st, 2007, 09:32
1985xjlaredo's Avatar
1985xjlaredo 1985xjlaredo is offline
X2 they are $7.50 at Oreilly auto here in KC, IIRC it is the one closest to the firewall.
Those 4 blue relays in the pic. Just take the front one and switch it with the back one. IIRC dont trust me on that though I think that the front is the AC and the back is the Latch relay.
Old June 21st, 2007, 10:47
yeah I know old man.I DO like my renix system,hell I've tuned it in by timming adjustments and air/fuel ratio tunning as well,my timming is electronically adjustable with a timming box for Chevy LS1's go figure,well anyways my ONLY problem is with the idle circuit,IF I were only electronically smart enough to de-bug that part of the pcm.....I'd be a millionare!!!!!!! as I have searched this deal a LOT and it is just a design flaw,from what I can see/read is there are a lot of renix owners out there that can't get rid of this issue either.Just tryin to find out what other people have done to resolve there idle issue so I can try what others have done to fix there's IF they have that is...................
Wont start; Rough Idle and then stalls when it does start MudslinginXJ OEM Tech Discussion 17 February 24th, 2008 08:30
1988 4.0L Renix Rebuild avnsteve OEM Tech Discussion 41 January 2nd, 2008 20:04
1988 Renix Coil Question 1985xjlaredo OEM Tech Discussion 12 May 9th, 2007 21:02
1988 Renix TPS readings gator_grabber OEM Tech Discussion 16 February 24th, 2004 14:57
'88 Chief Rough Idle or No Start or Perfect Start Hawaiian Style OEM Tech Discussion 8 June 9th, 2003 15:51
