Old June 19th, 2007, 21:36
codysown's Avatar
codysown codysown is offline
Exclamation Problems getting motor out.
I am new to this forum but not new to 4WD forums. I have found some valuable info on here, but I now find my self in a jam and have afew questions.
I have a 89 cherokee, 4.0L, Auto trans, in stock form. Engine is bad.
I found another engine and am in the process of swapping out. My problem lies in trying to get the top 3 bellhousing bolts out, and when I get the new one in, get them back in. These are not normal bolts. I cannot see them, only fell them. A 3/8 wrench is too big, and they fell like a star bolt. (the opposite of a torx).
The engine that is going in came out of a 87 cherokee that was wrecked. The wiring has all been left intact and should be a straight forward swap.
I do not want to pull the trans if at all possible.
Thanks in advance for the help and suggestions.
Cody
motor problems CV95XJ OEM Tech Discussion 1 October 23rd, 2006 07:26
Motor problems, need help fluidmotion Jeep Street and Performance 5 September 27th, 2006 00:16
Blower Motor Problems Bigsurf75 OEM Tech Discussion 9 April 18th, 2006 19:01
MORE motor mounts problems getting them bolted up Big Red Modified Tech Discussion 7 August 26th, 2005 10:45
motor problems-----help needed fluidmotion Jeep Street and Performance 32 May 17th, 2005 20:20
