Old May 13th, 2007, 20:59
avnsteve's Avatar
avnsteve avnsteve is offline
1988 4.0L Renix Rebuild
I'm tearing down a renix to rebuild. I have pix of what I've done so far and will post them soon. If anybody wants to ask any questions along the way, just let me know what you need. Also, and more importantly, anyone that wishes to offer any tips and or guidance, I'll be posting my questions up on this thread as well. I'll be sending out the block, crank, cam, and head to a machine shop for clean up and inspection. It doesn't appear that the block has been bored and you can still see the marks on the cylinder walls from the last honing, let's hope everything else is good too. My intention is to rebuild it as perfectly stock as possible, not a stroker or HO. I figure it was good enough for 200k miles, why not go for another 200k...
Old May 14th, 2007, 00:01
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: 1988 4.0L Renix Rebuild
I have one that was running fine when it was pulled at 167,000 miles that I had shipped down from Wisconsin recently. The owner replaced it with a V-8, stored it for 3 years planning a stroker, but then he sold it to me. I am planning to do a partial tear down, cleaning, inspection and replacement of all the seals and gaskets at a minimum. Not sure how far I will go but not planning to go the full route like yours. I will be watching for your posts.
May upgrade and replace a few things like the oil and water pump while they are easy to get too!
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old May 14th, 2007, 03:26
xjtrailrider's Avatar
xjtrailrider xjtrailrider is offline
I pulled mine and took it to a local race/machine shop to get a complete rebuild. The only thing I re-used was the block, crank, valves and head. They assembled the motor after all of the machinening and pressured it up. They punched it out 40 over, decked the block, milled the head, and reworked the valves.
$1700 total and 1 year 12k warranty.
I'm a mechanic and could do it myself but hey 2 weeks later I was driving it.
The head
engine assembled
Old May 14th, 2007, 05:15
avnsteve's Avatar
nice! that's what I'm talking about, love the pics, thanks!
Old May 14th, 2007, 07:30
Pigpen's Avatar
Pigpen Pigpen is offline
Man, oh,man, That looks nice!!!!!
Just a quesion. Why didn't you go with a after market exshaust header?
That would reallly look great and run nicer with all the work you did to the engine?
Still, looks great.
Pigpen
Old May 14th, 2007, 09:22
avnsteve's Avatar
that's xjtrailrider's engine in the pics, i haven't posted mine yet, but I am using stock because that's what i have, and upon inspection, there's no cracking, nor warping, so penny saved... I do plan to have the exhaust coated (ceramic) to help keep temps down in the bay a little...it's only about $100 here locally from what i understand
Old May 14th, 2007, 19:37
Still, looks great.
Pigpen
Yes that's my daily driver that I am doing a resto-mod on. Its basically stock(4.0,AW4,NP231), but it will get a few goodies which include 3.73 gears, a 29 spline 8.25, posi-lock front disconnect, and HD rear springs and a spacer in the front to level it. I already have a HD tranny cooler, tranny temp gauge, and a few other goodies. It runs good enough I don't need headers. I still run the stock manifold in all of my XJ's, I've found that the money is better spent other places. But everyone has a different opinion.
I have 4 XJ's so I wanted one of them to be nearly as stock as I could allow myself to go. This 90 used to be my Dads that he bought brand new, he passed away a few years ago so it is a tribute to him.
Some before and after shots
I also replaced all of the RENIX input/output sensers/devices etc. and the fuel injecters/pump, distributer, pressure regulator, if you can think of it it is new under the hood or under the Jeep.
Here is another shot of the finished motor, I've got 8k on it now, it runs great.
Old May 15th, 2007, 06:46
Pigpen's Avatar
Gentlemen, again I say Fine job. I was just curious. Your reasons are perfectly understandable to me.
Keep up the good work.
Pigpen
Old May 15th, 2007, 13:31
90Blue_XJ's Avatar
90Blue_XJ 90Blue_XJ is offline
Talking Re: 1988 4.0L Renix Rebuild
I live a few hours south of you and can not find a ceramic coater here can you post or PM me with a name and contact info?
Old May 15th, 2007, 13:34
scca28 scca28 is offline
I'm going through the same thing as we speak. I have a '90 motor I am going to rebuild for my '88 Laredo. Family and friends (who can afford new cars every two years) ask me why I am bothering with an almost twenty year old vehicle, and I reply with "Because I CAN!!!". Sure beats sinking into a couch watching American Idol with potato chip crumbs all over your belly...
Good luck with your project, have fun and take lots of pictures as you go. Lets us know of any good tips you discover along the way!
Old May 16th, 2007, 08:08
NXJ NXJ is offline
When you guys have your engines apart like this, and are ready to shell out $8K (quoted from xjtrailrider) - why not port and polish the cylinder head? There is more power than you can imagine to gain from that (from what I've heard the stock heads are pretty restrictive).
Old May 16th, 2007, 09:51
avnsteve's Avatar
My rebuild is an exercise in Keep It Simple. Once I install this BONE STOCK engine, and run it, I'll probably use the other one to build up a stroker, I may or may not install it, but will definitely build it
Old May 16th, 2007, 16:58
Daddycajun117 Daddycajun117 is offline
If I wanted to do a basic rebuild, what kind of parts would I need and about how much would it cost. I have an 89 XJ 6cyl with 193K
Old May 16th, 2007, 17:29
I did some shopping on Ebay, got a "master rebuild kit" for $400 on a "make offer" deal (comes with a lot of stuff, mostly bottom end), a reground crank with matching bearings for $99, and some specialty tools. Going to have to spend some money at a shop to, at the least, get the new pistons pressed onto the rods and the cam bearings pressed into the block. Add in the engine stand and crane I brought, along with the u-pull-it engine, I am just about at $1000.
If all else is okay, the rest is all blood, sweat and knuckle skin. I know the money goes out quick on a project like this, and it can get close to the cost of a purchased rebuilt, but for me it's a hobby. My current engine is getting me around for now, so I am not pressed for time (fingers crossed).
Old May 16th, 2007, 18:03
1985xjlaredo's Avatar
1985xjlaredo 1985xjlaredo is offline
Not to hijack your threadbut, I need to get my head done, 88 4.0L, nothing really wrong just wanna port and polish it, valve job and get it cleaned up. About how much should this cost me at a machine shop? Assuming I pull the headmyself and replace the rocker arms, springs and the rest?
i'm buying a Renix engine to rebuild $300 avnsteve OEM Tech Discussion 10 May 16th, 2007 16:06
1988 Renix Coil Question 1985xjlaredo OEM Tech Discussion 12 May 9th, 2007 21:02
Renix 4.0 rebuild MOOSE16285 OEM Tech Discussion 8 January 31st, 2006 12:17
anyone in cali swap a HO in a renix yr and pass smog like its a renix? RWKHausSupply Modified Tech Discussion 8 January 30th, 2006 14:55
1988 Renix TPS readings gator_grabber OEM Tech Discussion 16 February 24th, 2004 14:57
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
