| Advanced Fabrication and Engineering If you are worried about your project still being called an XJ or MJ, this is the place for you. If you haven't ever had a slag burn or know the smell of burning flesh, tread lightly. |
Thread Tools | Display Modes |
I know what you did last winter, spring, summer and early fall.
Well, thanks to Jes, I had to tear apart the best suspension I have ever built, in order to fit his old Atlas 4.3. The Atlas is bigger in almost every dimension, except for one. Because my old three link was built around an NV4500/NP231 combo, and all clearances were withing 1/4", I knew I was diving into a major reconstruct when I installed the Atlas. Knowing that, I figured I could also add a foundation for a future rear link suspension while I had everything out.
![]() These are the two new crossmembers, the drivetrain mount, and the T-case skid. The front crossmember is 2x4x.25", the rear is 2x4x.188. ![]() Here are the 4 components all assembled. The front crossmember attaches through frame sleeves with one 5/8" bolt, and two 9/16" bolt. The rear is two 9/16" bolts. The longitudinal drivetrain crossmember that goes betweeen the two suspension crossmembers mounts with 8 3/8" bolts. It is made from .188 plate cut and welded into a custom shape with a bit of drop to accomadate the skidplate which is formed around the bottom of the Atlas. ![]() Another view. The upper control arm mount is 2x2x.188", the LCA mounts are 3x3x.188.: ![]() Here are the members installed: ![]() And a closer view of the drivetrain mount. I'm especially proud of this piece, 8 pieces of steel in there, and a Wrangler spring bushing. Bolts in with 8 5/16" bolts through the Atlas cover. The "V" notch relief on the driver's side allows you to push the bushing out for service. ![]() Here's how the longitudinal drivetrain crossmember and the mount interface. 9/16" bolt holding it in place. ![]() Here is everything installed. LCA arms are my old 2"x.25" chromoly units cut down 4" to 35.5". Upper arm is 1.75" x .120". Heim at the frame side is a 1" bore, 1.25" thread. All other joints are RE's. ![]() Another shot: ![]() Things get kind of tight on the driver's side. The red tube above/next to the UCA is grafted into the floor, and catches a perpendicular 1.5" tube that has a washer welded in, and through bolts into the UCA mount. This reduces any potential movement of the UCA mount under braking, or landing. ![]() Another view. Thanks again to Billy for hosting. XJDB is the shiznit. Here you can see the vertical separation at the frame. On the old suspension, I had three holes: One that nearly equaled the vertical separation at the axle (one inch less), one that was an inch lower, and one two inches lower. I settled on the middle position, as nearly parralel had very little anti-dive which made the rear of the Jeep very light under hard braking in the dez or on fast fire roads. Knowing this, I just drilled one hole in the new mount to duplicate the geometry of the old junk. [IMG] [/IMG]All in all, I'm very happy with the way it all went together, and it's nice to know that I can add a rear triangulated 4 link without too much trouble in the future. Last edited by CRASH; 07-20-2006 at 07:26. |
#2
Re: I know what you did last winter.
How much shipped to 63385?
"Some cause happiness wherever they go; others, whenever they go." -Oscar Wilde Sheetmetal is over-rated. |
#3
x2, and it will have to be made for a LWB MJ, I assume you've got the measurements already.
1987 MJ 4x4 4.0 AX-15 34's, some stuff 1987 XJ 4x4 4.0 AW4 31's, Wife's rig. Quote:
#4
Nice work.
Would it be too much to ask you to really use the flat head c sunk allens under the cross members? It would be worth the entertainment value on the trail to hear what Richard would have to say, trust me. ![]() --ron |
#5
now hurry up with the cage work, dash and wiring!
#6
Pics in two weeks, very busy with my roof. I'm not embarrased to say that I didn't like the cage color and have to repaint before posting pics. Oh, and I had to grind and Bondo the welds inside so I didn't catch my skirt getting in and out. ![]() And Ron, I have to use the stainless pan head allens, anything less is not bling enough. Even if it means drilling them out for trail repairs.
#7
Allens are the best.
87 XJ |
#8
Its bolt in right?
A wise man once said: Quote:
#9
Rick BTW.....Nice work Crash. Will it ever see the dirt? |
#10
Now just repeat over and over......... ![]() How's that, Ron?
Richard Gauthier.........2008 and 2009 King of the Hammers finisher Team . 2010 King of the Hammers Team GenRight Offroad Thanks to , J.E. Reel Drivelines, Maxxis Tires, CTM Racing, Bishop-Buehl Racing Engines, BajaHID.com, MasterPull
#11
Looks really good, Andy. I still need to figure out my crossmember and skid plate, and where to mount the rear suspension. I like the extra mount on the Atlas, what was the thinking behind that? Hmmmm...........
What size rod ends did you guys use on the upper arm?
#12
Oh, I see, that is the only trans mount. Nice way of doing it.
#13
Looks really nice, Andy.
I love that design. |
#14
There are so many things wrong with this thread I'm not sure where to start.
1. Winter? Sure feels like July to me. 2. Allens? I didn't seem to have a problem with them at all. I thought it was a beer break. 3. Richard, just search you forgetfull old fart. http://www.naxja.org/forum/showpost....4&postcount=34 (at the bottom) 4. OT? The dope make you forget how to spell Okie? 5. Please clean and wax all parts before posting pics. |
#15
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| What job for the summer? | JeepXJ93 | Non-Tech / Off Topic | 13 | 03-28-2006 15:09 |
| winter (can we really call this winter?) projects | Kejtar | SoCal Chapter | 69 | 06-02-2005 12:19 |
| early style (84-early 87) tach cluster: sale | scase86 | For Sale: Private Party Only. XJ ITEMS ONLY | 0 | 05-18-2005 17:09 |
| Winter arrived a bit early....... | CRASH | Non-Tech / Off Topic | 7 | 11-04-2003 09:28 |
