Old April 22nd, 2007, 21:34
ALL PLAY's Avatar
ALL PLAY ALL PLAY is offline
Working on a dana 44 and 9" build
I have a chance to get a dana 44 and 9" out of an early bronco. My question is it worth all the effort and modification. Would be stronger or should I just up what I got. I am running an open 30 and locked 35 no other mods to the diff. w/33's and 4:10's.
All comments welcome.
Thanks for the help in advance.....
Old April 22nd, 2007, 23:40
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Re: Working on a dana 44 and 9" build
No doubt the 9 inch is worth the effort. 3-4 times better than a 35. Would be good for a much larger tire than what you have now.
The 44 to me isn't worth the trouble if you're running 33's. Much easier to put in some good axles (which you'd need to do to the 44 too) and forget about it. If you hop up to 35's it might be worth the extra reliablity to go with the D44.
I would definetely regear to 4.56 or 4.88 if you are gonna stay with 33's or 35's.
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old April 23rd, 2007, 01:36
JEEParon JEEParon is offline
i did the swap on my 92, but i used full width from 78 bronco. i run 36 iroks and 5:13's open front, spool rear. i've had it done for quite awhile and haven't had any problems with breakage yet.
Old April 23rd, 2007, 02:01
mike86xj mike86xj is offline
not trying to hijack but what shafts are in the front? stock, alloy?
what about the rear 30 spline?
Dana 44 pictorial build 87xjco Modified Tech Discussion 22 December 10th, 2012 16:12
Dana 60 Build up caglezxj South East Chapter 0 March 1st, 2007 13:59
Dana 300 build BonesBrosChris Modified Tech Discussion 7 December 5th, 2006 15:48
Cost to build Dana 44 Jump This Modified Tech Discussion 17 March 26th, 2006 17:07
Need Dana 44 build information XJWheelie Modified Tech Discussion 1 November 28th, 2004 04:06
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
