Old July 18th, 2006, 20:17
philip_g philip_g is offline
is this death wobble?
While my XJ doesn't violently shake, it feels super unstable. On the freeway if you hit a bump it'll "wag" back and forth (side to side, left to right) for a few seconds. Nothing in the wheel, it just feels tippy is all.
Shocks are new in the front, have new rears to go on but haven't gotten to it, the fronts didn't make any difference and the rears seem to be OK but I'll replace them anyway.
The wheel doesn't go crazy so I didn't figure it was the stabilizer, but I guess I really don't know what's going on with the thing, suspension is basically stock aside from the new shocks and an AAL in the back (did this before the AAL)
Old July 18th, 2006, 20:19
fizassist's Avatar
fizassist fizassist is offline
NAXJA Member #1052
Re: is this death wobble?
If you have to ask...
Seriously, there is no uncertainty when you have "death wobble"; your first thought is "Thank God I made it out of that curve alive." The type of suspension/steering sloppiness you mention can have the same root causes, though, and could lead to DW in adverse situations.
Old July 18th, 2006, 20:20
kennzz05's Avatar
kennzz05 kennzz05 is offline
basic dumbass
front end alignment?read gojeeps page about how you can check it with a tape measure to get an idea if its out of line
Old July 18th, 2006, 20:21
That's sort of what I figured, i've had wranlgers with shot dampers before and when you hit a bump it's pretty wild.
This is just such an odd problem, I thought when I first got it I was on crack but loaned the car to my buddy and he mentioned the same thing.
I'll check it out, thanks!
Old July 19th, 2006, 15:49
creeperjeep's Avatar
creeperjeep creeperjeep is offline
The only time ive had what you described happen is when i had no swaybars and bad shocks
I replaced the bad shocks and it stopped rocking on the hiway
Wobble of Death ang31-0f-d347h Modified Tech Discussion 4 March 5th, 2005 18:16
Death Wobble live24wheel Modified Tech Discussion 7 March 1st, 2005 14:53
xj death wobble big cherokee Modified Tech Discussion 12 February 9th, 2004 18:40
NOT Death wobble zero2fearo Modified Tech Discussion 2 September 6th, 2003 09:23
Death Wobble.....HELP!!!! BillO1s OEM Tech Discussion 18 April 30th, 2003 20:24
