Go Back   NAXJA Forums -::- North American XJ Association > Bargains and Deals > For Sale: Private Party Only. XJ ITEMS ONLY
For Sale: Private Party Only. XJ ITEMS ONLY Private Party Ads only. If they even smell commercial, they will be deleted.
Old April 10th, 2007, 20:45
Safari Ary's Avatar
Safari Ary Safari Ary is offline
Lincoln Versailles(Ford) 9" rear end, 58.5" wide, 5x4.5 bolt pattern, discs $700 OBO!
This is the rear axle from a Lincoln Versailles.
Hey everyone, haven't been around here in a while, but I have this axle for sale and it is almost ideal for an XJ.
It is a Ford 9" rear end with factory discs.
The rear axle is 58.5" wms to wms with 5x4.5" bolt pattern.
Swap this into your XJ or MJ and never break your rear axle again.
I don't know what the gear ratios are, but they are very tall, so you'd probably wanna swap them out.
Axle is located in Blacksburg, VA, but can be delivered to the DC area or NC relatively easily.
$700 OBO(seriously, make me a REASONABLE offer)
Ary
Old April 11th, 2007, 15:42
xrayjeeper83 xrayjeeper83 is offline
Re: Lincoln Versailles(Ford) 9" rear end, 58.5" wide, 5x4.5 bolt pattern, discs $700 OBO!
Off topic but what is fords model on this?
Andrew
Old April 11th, 2007, 15:53
Safari Ary's Avatar
I honestly have no idea what the Ford counterpart is. Sorry
Old April 11th, 2007, 16:41
After a bit of searching its the gernado(sp), what is the spline count, and is it big or small bearing?
Andrew
Old April 11th, 2007, 18:22
Safari Ary's Avatar
It is 28 spline, and IIRC does not use standard "small" or "large" bearings. I do believe moser, dutchman, etc offer 31 and 35 spline axles for this application though due to it's swap popularity. Not positive though.
We bought this axle for my uncle to use in a Lotus 7 w/ an LS1 for an engine, but decided to go another route. This was pulled from a running/driving car and is complete.
Ary
Old April 15th, 2007, 21:44
Safari Ary's Avatar
Bump!
Old June 29th, 2007, 20:57
Safari Ary's Avatar
New price $550
Currie 31 SPLINE AXLE SHAFTS 5 x 5.5 BOLT PATTERN 9" cracker SoCal For Sale 0 April 25th, 2006 01:56
Wanted: 5 matching wheels with 5x5.5" bolt pattern Menzenski NAC Classifieds 3 April 12th, 2006 18:57
Jeep Bolt Pattern Vs 8.8 Ford LETNER Modified Tech Discussion 6 February 7th, 2006 11:40
D44 front with 5 on 4.5" bolt pattern Roxtar Modified Tech Discussion 23 October 20th, 2005 07:50
5 on 4" bolt pattern... what vehicle has it? Kejtar Tow Rigs and Trailers 5 June 19th, 2004 00:47
