Old July 15th, 2006, 00:03
low pressure low pressure is offline
alternator upgrade 160 amp ?
has anybody tried or done this upgrade? i know the dodge durango 136 amp are swappable to our alterantor, would it be the same with the 2002 and later durango alternator with the 160 amp and will it be safe to run with our XJ without major wiring concerns? any input will be appreciated.
Old July 15th, 2006, 00:51
5-90's Avatar
5-90 5-90 is offline
Re: alternator upgrade 160 amp ?
Link in sig - I can source high-current wiring for you, and San Jose Generator can source high-output alternators. Check both of us out (I built the pages for Rod at SJG, but you still deal directly with him. Contact information is on the pages.)
5-90
Old July 15th, 2006, 01:10
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
Forgive me if I seem dull about this...
The newer XJs use the PCM to supply field regulation for the Alternator, and I have always thought that you used a reguator for a specific application....
So, if you installed one of these Delco style high output Alternators, wouldn't it throw a code?
Or, if you put on a larger that stock Alternator of the same flavor, wouldn't it demand more ( or a different) output from the computer to regulate the field?
Old July 15th, 2006, 01:21
5-90's Avatar
Yes, installing a Delco would throw a code. However, Rod also makes high-output Nippondenso alternators, which are compatible with the PCM regulator that ChryCo came up with (which still doesn't seem like a good idea to me, but I never did like integrated assemblies. I vastly prefer the "modular" approach, which makes it easier to service a system rather than having to replace a component that controls everything.
5-90
Old July 15th, 2006, 10:07
5-90
what will be the big difference between his alternator and the one i can get off the yard of the store? i will consider your wiring. just need to be sure it will work.
Old July 15th, 2006, 14:17
5-90's Avatar
I think the big difference will be the fact that, unlike the store, you'll be dealing DIRECTLY with the guy that does the rebuilding and testing: and, unlike the yard, you'll KNOW what you're getting.
I've always been a little leery about buying electrics from a yard - especially if I don't plan on rebuilding them first thing.
As far as fitment, his units WILL fit - unless you specify something non-standard for your application - which will also make your life easier.
I can't think of any search keys offhand, but if you pillage around here, you'll see where we've beaten the idea of "mass market rebuilds" to death - they're bought by the chains for a fraction of what you pay, a "lifetime warranty" is offered because failures are common (while I was wasting time behind the counter, a return rate of 60-120% was not uncommon. Yes, some were returned SEVERAL times!) and the stores are paying low costs and playing the odds on the rebuilds.
Sorry, but "Homie don't play dat." Rod's work is truly "install and forget" - he rebuilds everything right there, and it don't go out unless it's been bench-tested. The only time I've had to buy anything like a "replacement" from him is when I'd gotten another vehicle, and didn't have a spare on the shelf when I needed one.
5-90
Old July 15th, 2006, 15:43
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
i can vouch for the upgrade cables as well, well worth the investment and priced competively. Jeep starts better, lights are brighter, etc. even with the stock 90 amp alternator and the ANL fuse kit is well worth it if you're jumping up to a high amp alternator and need a high amp type fuse protection.
I certainly wouldn't plan on upgrading to a high amp alternator and running that power through the factory harness. Golf balls and garden hoses come to mind.
Recorder
I had a 4 door Jeep before it was cool . . .
Old July 16th, 2006, 15:04
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
I just upgraded my power cables in preparation for a future 130amp alternator swap (it's been sitting in a box for months). Here's my write-up:
http://www.angelfire.com/my/fan/Power_Cables.html
A big thank you to John (5-90). . Without his helpful info. I don't think I would have tackled the job by myself.
Old July 16th, 2006, 15:18
5-90's Avatar
Thanks! I certainly didn't expect a link...
If I was allowed back in that area, I'd have to remember to be nice to you someday. If you ever make it over to the States, let me know (I was declared PNG by the US State Department back in 1991, and I think I'm still on the blacklist for a visa. Oh, well - I wasn't that interested in going back to Araby anyhow, to be perfectly honest...)
5-90
Old July 16th, 2006, 19:44
MrShoeBoy MrShoeBoy is offline
5-90
So by not allowed back...Did you do something bad or suspecious to warrent that? I dont mean to pry, I was just wondering.
AARON
Old July 16th, 2006, 20:01
5-90's Avatar
I had a "difference of opinion" with some oil princes while I was out and about.
Granted, I wasn't out alone - I was with a female NCO with whom I was rather "friendly" at the time. The Saudi opinion of women is not stellar to begin with, and their opinion of women in uniform flatly sucked.
I ended up bouncing them off of a few brick walls. Oddly enough, it was the US that said I wasn't going to go back there again (the Saudis otherwise didn't seem to care - go figure!) and, as you can imagine, I was real hurt by that... No booze, and no bacon or sausage with my eggs? I grew up on that stuff - I didn't want to go there in the first place!
My CO told me it was the first time EVER any man under his command managed to get thrown out of an entire country...
"Chaos, panic, disorder. My work here is done."
5-90
Old July 17th, 2006, 01:02
Dr. Dyno's Avatar
5-90
That probably only applies to Saudi Arabia. I don't think you'd have any problem coming into the UAE and if you ever do make it over here, give me a call (I'll give you my mobile phone no. in advance). You'd be more than welcome. The UAE is a lot different than Saudi in many ways; like chalk and cheese. At least here you can buy bacon, pork sausages, and booze.
As for the link to your site in my write-up, it's the least I could do since you gave me such helpful info. and saved me a fair wad of $$$.
You probably noticed that I added two extra ground cables on my Jeep. You could copy them and offer them as a kit together with the other cables. The only thing you'd need to add is an 18mm hex nut with a 1/2" thread to secure one of the ground cables to the front driver's side head bolt.
Old July 17th, 2006, 01:11
5-90's Avatar
I do offer a replacement for the cylinder head ground (usually a 10" BLK 3/8" x 1/2", using original hardware. I think that nut is more properly 11/16", tho...) and I've been kicking around adding a ground (probably use 4AWG for it) to replicate the ground added by ChryCo in 1991. I just haven't bothered yet, to be honest.
I'm glad my advice worked out for you. And, you're probably right about UAE - sounds like I might almost enjoy it. Still, I usually need excuses to travel somewhere, and I'm thinking if I DO go to UAE, it's going to be en route to some strenuous OPEC negotiations to see about getting this "price" thing under control. Start with OPEC, then work on the refiners (who are also part of the problem...)
5-90
Old July 18th, 2006, 10:01
Dr. Dyno's Avatar
5-90
Oh, I wasn't referring to the cylinder head to firewall cable replacement for that stupid braided strap. I was referring these extra two cables that you could add to your kit:
Block to firewall: 26" length, 3/8" x 3/8" loops
Cylinder head to battery: 31" length, 1/2" x 3/8" loops
With a total of five grounding cables (battery to block, block to firewall, firewall to head, head to battery, battery to inner fenderwell) instead of three, the grounding system will be just about bombproof.
The same size nut that holds the head to firewall cable to the rearmost driver's side head bolt will also work for the head to battery cable (at the front driver's side head bolt end). Like I said, it has a 1/2" thread and is definitely 18mm so you can add that to your cable kit as well.
John, you would DEFINITELY enjoy the UAE. Compared to Saudi, it's almost like being on a different planet. As for OPEC, they produce only ~45% of the world's oil output so they can have only a limited influence on the oil price. Even if they cut production to drive the oil price up, non-OPEC countries (especially Russia, Nigeria, and Venezuela) take advantage by increasing production to bring it down again, increasing their market share at the same time. What's driving the oil price steadily higher is mostly a rapidly increasing demand for oil by India and China. Between them, they have 2/5 of the world's population and their economies are growing at an astronomical rate. The OPEC countries are already producing oil at near full capacity so the extra demand can only really be made up by non-OPEC countries. One thing's for sure. The Gulf states are making a hell of a lot of money, the UAE is very rich, and you can see that in the number of skyscrapers that are popping up all over Dubai and Jebel Ali (including the Dubai Tower which will become the world's tallest building). It's truly jawdropping.
Old July 18th, 2006, 10:10
5-90's Avatar
Yeah, I'd figured I'd have to go to Venezuela next - what are they paying for gasoline, something like twenty-five cents a gallon?
How do you route that head to battery cable without hanging up on anyting, anyhow? I'm a bit curious about that. Also, why? I'd think you'd have a good ground there as long as your head bolts are sound, using the main block ground (and if your head bolts are unsound, you've got bigger problems anyhow, haven't you?)
Last question - one of the pix of your cables almost looks like they're "spiral-wrapped" of some sort - is that tape for colour-coding, or did your cable come that way? I've not seen that before...
Yeah, I suppose my views of Araby are tainted by my first visit - much like my views of France (the first time I went there, I was sent to Paris. Ugh.) Still and all, I haven't found any reasons to go back, and we're planning on going to Scotland, maybe Germany and Greece, for our tenth (I really do want to see Balnagown Castle...)
5-90
alternator upgrade mark91xjbeef Modified Tech Discussion 2 March 18th, 2011 07:31
Upgrade from stock Alternator EMSJEEP Modified Tech Discussion 13 July 15th, 2006 10:40
90 Alternator upgrade? Slo-Sho Modified Tech Discussion 4 December 8th, 2005 20:56
1989 Alternator Upgrade canook2u Modified Tech Discussion 4 October 30th, 2003 18:28
Alternator upgrade Erik Litchy OEM Tech Discussion 3 June 15th, 2003 22:37
