Upper control arms?
Kilted XJer
Ok... I know I'm retarded, but I didn't realize that I even had upper control arms until today. I lifted my last xj and didn't notice they were there. I've since bought a new xj that already had a 3" lift. I'm going to do a 2" bb in a few days to bring me up to 5". I was going to replace the LCAs because it currently has stock length, but now I'm wondering... should I replace lower and upper? Money is an issue... Should I even replace either set of CAs now? I've know people who ran 5 and even 6 inches without replacing the stock CAs.
-Jeff
It's a good idea to change the uppers, but not necessary. You should get adjustable lowers so you can adjust the pinion angle. Sure, you can run with 6" of lift and stock arms.........you can also run with 35's and stock gears. Neither is a good idea.
