Old July 12th, 2006, 17:32
WNT1's Avatar
WNT1 WNT1 is offline
DEATH WOBBLE AT 40 MPH
I was hopeing someone could shed some light as to why I've got Death Wobble at 40mph after a fullwidth front and rear axle swap?????
Here is what I've done so far.
Swapped in a 1979 HP D44 front and the D60 out of the same truck in the rear. I am running a 3 link Rockkrawler 8" system on my 96 XJ. I've had it professionally aligned after the swap and it's reading perfect. The front measures 5.9/ 6.1 degrees of caster. The pinion angle is better now then w/ the stock D30. I've called RockKrawler and their techs say the 3 Link setup will work even w/ a Front D60 axle swap? So the weight of the fullwidth D44 should not be an issue??? I'm running 37x13x17 tires on 17x9.5 Allied Beadlocks!!
Here are some photos of the setup!!!
Old July 13th, 2006, 06:25
Frank Z's Avatar
Frank Z Frank Z is offline
Re: DEATH WOBBLE AT 40 MPH
I'd start with the wheels and tires. Have the balance checked out. Have you looked to see if you've lost any weights?
More Death Wobble! haligan Modified Tech Discussion 2 June 18th, 2005 20:13
94 XJ Death Wobble TMiller49er OEM Tech Discussion 2 May 22nd, 2005 19:16
88 xj death wobble jeep88xj OEM Tech Discussion 1 May 22nd, 2005 08:34
Death Wobble atomno1 Modified Tech Discussion 14 March 29th, 2005 15:38
Death Wobble.....Help!!!! 87_jpchrk Modified Tech Discussion 13 November 6th, 2004 20:41
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
