Old February 24th, 2007, 14:32
jacked jacked is offline
alternator relocation...
has anyone relocated their alternator up to the a/c compressor location? my a/c has never worked anyway so i want to remove the compressor and put the alt in its place. are there any oem brackets that can be used or would it be custom?
Old February 24th, 2007, 15:09
tealcherokee's Avatar
tealcherokee tealcherokee is offline
Re: alternator relocation...
pm me, you can come see my set up considering your about 30 min from me
Old February 24th, 2007, 15:14
BBeach's Avatar
BBeach BBeach is offline
Ive heard of someone using an older commanche 4 cylinder bracket but Im waiting on this myself.
Old February 24th, 2007, 15:41
i guess ill repost this.... YOU NEED A RENIX AC BRACKET TO DO THIS!!!
the first thing i did, was remove the AC, and relocate the altenator. this was a pretty easy job, once we figured out what to do. This only works for renix setups. but making 1 adaptor, and using some washers, it bolts to the stock AC mount. a 75" belt was needed (24" shorter than stock!)
1
2
3
4
5
6
7
8
Old February 24th, 2007, 20:06
dt00th dt00th is offline
yep i did it after killing 2 alternators in 6 months..check the link out below i have other pics but on other H/D which isn't connected at this time .
http://www.rockznrutz.com/forum/gara...em&image_id=17
this is version two as the first idea was ok but could get the belt to run true so i cut the orginal bracket rerouted the belt .
Old February 24th, 2007, 20:30
mikes offroad's Avatar
mikes offroad mikes offroad is offline
I have never tried it but I thought you could us the brackets off of a YJ. They had there alt located up top or maybe one off of the new XJ's
Old February 24th, 2007, 20:42
BBeach's Avatar
What about this of us that dont have RENIX?
Old February 24th, 2007, 20:46
you need to get the renix ac bracket from a junk yard, it bolts right on, thats a 96 block in the pics
Old February 24th, 2007, 22:22
BBeach's Avatar
You've got quite the mix there, looks like mustang or SHO tb, 99 intake, renix ac bracket, 96 head...Anyways, do you have to remove the battery at all for this installation? No drilling required at all? If its just in and out then I'm up for trying it.
Old February 25th, 2007, 09:04
awesome! just so happens that my XJ is a 90 renix. i plan on upgrading to a HO head in the future but you say it will still bolt up? I was also planning on replacing the mech fan with an electric one and removing the pulley for it like in the pic on the link up above.
Old March 1st, 2007, 20:06
BBeach's Avatar
Does anyone have a spare one they wouldnt mind shipping me?
Alternator Relocation ???? AngryDog Modified Tech Discussion 40 October 23rd, 2007 07:00
Alternator Relocation scottsxj Modified Tech Discussion 4 February 27th, 2006 19:55
CPS Relocation Kit... L4V OEM Tech Discussion 15 December 25th, 2005 00:28
Alternator relocation crazyoffroader Modified Tech Discussion 4 August 24th, 2005 11:33
Alternator Relocation xj4life Modified Tech Discussion 8 March 15th, 2005 16:17
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
