Old February 2nd, 2007, 18:50
cherokee4fun cherokee4fun is offline
1990 Electric seat wiring harness????
Hi,
So, I have a 90 with manual seats, but I have a nice pair of leather electric seats out of a 90 Limited. I wanted to switch them, but when I removed the old seats, there was no wires!!! Surprise!!
SO , I pulled out my parts CD and it appears that there is a wire harness that feeds the seats. I did find a empty wire connector that comes out of the console and goes under the carpet, I assume that is where this mystery wire harness gets it's power from, but I could be wrong!!!!
Anyone have any thoughts on the best way to make this happen? Anyone have a wire harness from a donor? I looked today at a wrecker, the only one with electric seats, some one had already beat me to it. Anyone think I should avoid electric seats? I usually don't do much adjusting, so I am not to concerned about multiple drivers.......
Thanks in advance!!
Bob
Old February 2nd, 2007, 20:20
Sting25's Avatar
Sting25 Sting25 is offline
twitter.com/cmchadwick
Re: 1990 Electric seat wiring harness????
run new wires for it.....just tap a 12volt source or run new wires from the battery.. make sure to install a fuse I am not sure the amps.
I need a wiring harness willmiller OEM Tech Discussion 0 January 8th, 2007 17:04
wiring harness for '91 4.0 I6 HO Skullver Modified Tech Discussion 3 August 18th, 2005 14:27
Wiring Harness TBLimited OEM Tech Discussion 2 February 16th, 2005 19:20
5 point seat harness etaniyani Modified Tech Discussion 7 February 8th, 2004 09:14
Wiring harness keith haw OEM Tech Discussion 6 August 14th, 2003 03:38
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
