Old August 18th, 2003, 21:25
onetallmj onetallmj is offline
dead battery now no start
Went to start truck( 88 MJ with 4.0 auto), no start. Found battery very dead. Jump with cables, got it to turn over but very weak even after a long charge time. Replaced battery with an almost new battery. Engine turned over but no go!! Everything was working fine last night . Do I need to reset something after replacing the battery?
Help
Wade
Old August 18th, 2003, 21:58
RichP's Avatar
RichP RichP is offline
Clean your grounds on the engine, firewall and frame first. What is the voltage on the 'almost new' battery ??
Old August 18th, 2003, 23:36
91xjtim's Avatar
91xjtim 91xjtim is offline
First thing Id do is take apart all connections and clean them off real good with a wire bruch or baking soda. Also, get an vom meter and check battery voltage.
Need Help! Won't Start...Stuck At Work! pancake OEM Tech Discussion 11 October 16th, 2003 21:57
Incab battery shut off switch Speed_racer OEM Tech Discussion 7 August 22nd, 2003 16:31
Battery going dead, Help GRNT Modified Tech Discussion 3 June 25th, 2003 09:48
'88 Chief Rough Idle or No Start or Perfect Start Hawaiian Style OEM Tech Discussion 8 June 9th, 2003 15:51
Push Button Start? FatXJ Modified Tech Discussion 10 April 5th, 2003 19:17
