Old January 10th, 2007, 00:57
Gold Cobra Gold Cobra is offline
H.O. Cooling system on Renix
I have a chance to raid a 93 xj for parts and was wondering if i could use the entire cooling system on my 87 4.0. any links to info i searched and couldnt find anything. is this possible?
Old January 10th, 2007, 01:23
Slo-Sho's Avatar
Slo-Sho Slo-Sho is offline
Re: H.O. Cooling system on Renix
Yup.
Old January 10th, 2007, 01:36
Originally Posted by Slo-Sho
Yup.
Wow thanks for the help buddy.
Old January 10th, 2007, 04:27
ratherbcamping's Avatar
ratherbcamping ratherbcamping is offline
You need the radiator, overflow line and tank and the heater valve assembly. I think that about it.
Old January 10th, 2007, 09:13
BIGSLVRXJ's Avatar
BIGSLVRXJ BIGSLVRXJ is offline
Give some of these a shot bud. I think Slo-Sho was saying you should probably search around a little more, this is covered around here pretty frequently. In short you will need the radiator, overflow bottle, heater valve and hoses from a 91< XJ.
http://jeepsunlimited.com/xj/cooling/cool.htm
http://jeep.off-road.com/jeep/articl....jsp?id=257864
http://xjnation2.homestead.com/radiatorconversion.html
http://www.olypen.com/craigh/rad.htm
1990 XJ Pioneer-5.3 swap in progress-Original "BIGSLVRXJ"
1997 XJ Country-4.0, AW4, NP231, D30, C8.25, 4.5" RE Lift, 32" KM2s "BUMBLEBEE"
2001 XJ Sport-4.0, AW4, NP231, D30, C8.25 "Stock"
-Collin
Old January 10th, 2007, 12:02
jfiscus jfiscus is offline
You'll also need a thermostat & temp sensor housing won't you?
That's how mine knows what temp my motor's at since the open radiator doesn't have the sensor hole in it.
Old January 10th, 2007, 19:12
BIGSLVRXJ's Avatar
Well the temp sensor for the computer can be left in the same place, and so can the one for the gauge. The one you must've relocated to the t-stat housing must be for your electric fan. My GDI radiator that I bought had the bung in it for just such a conversion. No the t-stat housing isn't necessary however, I did it at the same time just so I could move my computer one up to it. For some reason the thermostat went from a 194 to 195 between 90 and 91 so I don' think that's crucial either.
-Collin
90 cooling system AZRockRunner OEM Tech Discussion 1 May 22nd, 2006 21:39
XJ Cooling System sgtpeeper OEM Tech Discussion 4 June 26th, 2005 08:04
Cooling system Q&A dyna OEM Tech Discussion 1 May 16th, 2005 09:44
Help Please-Cooling system cardboard OEM Tech Discussion 12 August 8th, 2004 17:45
Air in the cooling system.... sstanton OEM Tech Discussion 5 October 30th, 2003 13:10
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
