Old January 6th, 2007, 08:55
BrokenXJ BrokenXJ is offline
TJ serp belt tensioner, maybe XJ also.
I am replacing the serp belt on a 2000 TJ. It has a spring load belt tensioner? I suppose the new XJ's have this style also. Could someone give me some instruction on how to install the serp belt with this kind of tensioner?
Old January 6th, 2007, 09:10
falcon556's Avatar
falcon556 falcon556 is offline
I have not Confirmed, or I used a BAD email Addy
Re: TJ serp belt tensioner, maybe XJ also.
I am not familliar with the TJ, however I have replaced a number of belts with tensioners.
Basically you have the tensioner spring loaded pulley pushing against the belt.
You need to release the tension on the belt by moving that pulley away from the belt. The tensioner usually has a square hole where you attach a breaker bar or rachet and lever the tensioner away to release the tension. It could also have a place where you attach an open wrench. While holding the tensioner away, get the belt off the tensioner pulley and then you can carefully let the tensioner go to its rest position.
Get the new belt in place, move the tensioner away again so that you can rest the tensioner pulley on the belt and you got it.
Old January 6th, 2007, 10:03
SlimsXJ's Avatar
SlimsXJ SlimsXJ is offline
Smile Re: TJ serp belt tensioner, maybe XJ also.
On my 01xj the belt is adjusted by the power steering pump,you need to loosen the mounting bolts ,then turn the adjusting bolt,make sure to tighten all bolts when finished!
1990 xj serpentine belt tensioner location? Smittty9785 Tow Rigs and Trailers 2 February 7th, 2009 16:26
Belt Tensioner JeepCherokee OEM Tech Discussion 2 June 20th, 2006 22:31
Broke belt tensioner bolt...... Fred85 OEM Tech Discussion 11 February 13th, 2006 20:57
belt tensioner bolt... dizzymac OEM Tech Discussion 5 August 5th, 2005 17:10
belt tensioner jeep_cj8 OEM Tech Discussion 3 July 11th, 2003 09:54
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
