Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Advanced Fabrication and Engineering
Advanced Fabrication and Engineering For when your build is going off the charts. Wildly modified vehicles and straight up buggies welcome.
Old January 2nd, 2007, 20:47
CAVE's Avatar
CAVE CAVE is offline
My unibody "stiffeners" .......... frame rail strengtheners upgrades tie in
I just made these this weekend because of my soon to be radius arm/long arm upgrade.
http://1997jeepcherokee.blogspot.com/
Let me know if there is any incorrect info.
Ignore the post title, just did that for searchers.
Old January 2nd, 2007, 22:48
aparke4's Avatar
aparke4 aparke4 is offline
Re: My unibody "stiffeners" .......... frame rail strengtheners upgrades tie in
thats very smooth... i like it a lot and it really conforms to the stock rails... nice job i think i am going this route soon considering some kits are 150 plus... nice work... did you use a combo of self tappers at all or just plug welds?
Old January 2nd, 2007, 22:53
One Arm Steve's Avatar
One Arm Steve One Arm Steve is offline
Nice job. I like the idea of the blog, very cool!
Old January 2nd, 2007, 23:12
CAVE's Avatar
Aparke4-
No self tappers. Just plug welds and stitch welds. I would stay away from the self tappers if it were me. Just my opinion though. Im sure others would agree
Old January 2nd, 2007, 23:51
aparke4's Avatar
thanks for the response thats what i am going to do then... i like the idea of the nuts welded in the bracing for any addition skids or cross members... very cool thanks again
Old January 3rd, 2007, 02:39
English XJ's Avatar
English XJ English XJ is offline
I really like the look of those, and like your web-page / blog too.
To save me (an others probably) some time, do you have measurements of the angle used, including the location&length of the 'bent' piece in the centre??
It would be really appreciated as I could start some material orders and fabrication done before getting under the Jeep in the wet & cold (it's parked away from the workshop at the moment).
Thanks in advance and well done again.
Old January 3rd, 2007, 03:38
aszaunmi's Avatar
aszaunmi aszaunmi is offline
I agree very nice. It would be great to have the angles posted. I am getting ready to do the TnT Y link upgrade. It would be sweet to know these angles as I think I am going to do this at the same time as the upgrade.
Old January 3rd, 2007, 06:09
heapxj's Avatar
heapxj heapxj is offline
Very nice work, very sleek looking.
Old January 3rd, 2007, 07:14
CAVE's Avatar
I dont remember exactly the angle measurements, but the two notches are made approx. 7 inches apart measuring from the bottom of the notch. I think I made mine with about a three eights gap at the top of the notch which will bring the angle pretty close. The total length of each side is 5 feet which will leave you a little extra to box around the rear spring hangers. I made my first notch at 2 feet if I remeber right and the second one 7 inches from there. Hope that is enough to get you started, but make sure to make your own measurements once you get your material.
Old January 3rd, 2007, 09:30
chris420 chris420 is offline
Very nice I will put that on my list. I gues mine will not be as long because of the Full Traction Long Arm brackets that are attached to the unibody.
Old January 3rd, 2007, 12:47
XJrambler XJrambler is offline
The angles are 4 degrees.
Rate This Thread:
unibody strengtheners/use what when? wrecklaw71 Modified Tech Discussion 29 March 21st, 2008 20:48
XJ frame stiffeners 2offroad Modified Tech Discussion 57 May 26th, 2006 16:39
does anyone run with frame strengtheners on their jeeps? jeepster89 Modified Tech Discussion 24 January 27th, 2006 21:40
unibody strengtheners?? I'llpullyaout Modified Tech Discussion 16 September 28th, 2005 17:18
Anyone running Detours XJ Unibody "Rok Slyder" wescam Modified Tech Discussion 8 March 23rd, 2005 15:38
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
