Old December 29th, 2006, 15:00
ccflexj's Avatar
ccflexj ccflexj is offline
power steering pump reservoir
is there a way to take the reservoir off without taking the power steering pump off?
Old December 29th, 2006, 20:08
ccflexj's Avatar
Re: power steering pump reservoir
can someone please help i need to get this done tomorrow
thanks
Old December 29th, 2006, 20:51
Blaine B.'s Avatar
Blaine B. Blaine B. is offline
The pump is easy enough to remove, fyi. It's just a handful of bolts to remove. Much easier to access, FYI.
Old December 29th, 2006, 21:01
FatXJ's Avatar
FatXJ FatXJ is offline
not that I have found!
Why do you ask?
Old December 29th, 2006, 21:03
5-90's Avatar
5-90 5-90 is offline
1) You don't give with the year. Usually helpful information...
2) Typically, no. The only way that is often possible is if the pump and reservoir are separate units. Elsewise (and especially with the Saginaw pumps that GM, AMC, and ChryCo uses...) the screws to retain the pump pass through the reservoir anyhow - so you need to remove the pump to remove the reservoir.
5-90
Old December 30th, 2006, 02:06
ccflexj's Avatar
thank you ill just take the pump off then, and it was off a 96
Power steering reservoir emergency SCW Intermountain Chapter 4 September 24th, 2006 19:38
Power steering pump reservoir CGEMC OEM Tech Discussion 3 March 11th, 2006 15:02
Brake Fluid in the Power Steering Reservoir RedBluff OEM Tech Discussion 4 September 16th, 2004 22:43
Gluing Power Steering Fitting on Reservoir PaulJ OEM Tech Discussion 2 August 21st, 2004 08:58
Glueing Power Steering Reservoir return tube L92XJ OEM Tech Discussion 4 March 19th, 2004 11:15
