Old December 15th, 2006, 13:18
Zoro Zoro is offline
Older Rear WIper motor on newer XJ, wiring Q
Can anybody tell me what wires need to be spliced to make an older rear wiper motor(87-90) work on a 97+ XJ? On the older one there are 3 wires and the newer one is 4, I know this will work w/splicing but I forget what goes where, it's been awhile. I did one awhile ago for a 91-96 Jeep, is it the same setup as the 97-01? The one I did had the relay on the motor.
Thanks for the help
Old December 15th, 2006, 14:38
Re: Older Rear WIper motor on newer XJ, wiring Q
Figured 2 of the 3 wires so which wire coming from the relay on the 97-01 Cherokee is the ground, there is a Green, White, and Purple wire. However on the old motor the Purple and White went to the same place.
Old December 15th, 2006, 22:25
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
The diagrams in both the 95 and 99 books show the ground wire as black. On the 95, white goes to terminal 4 - park; brown/red to terminal 3 - run; black/yellow to terminal 2 - wash (I think). Terminal one, black, is ground.
Whoever did the schematics for the 99 book must have been on crack. They're cryptic and full of gaps. As usual, the connector listed (C 310, the main harness connector at the top of the liftgate) is omitted from the pinout illustrations, and no connector at the motor itself is identified, although I'm pretty sure there is one.
But anyway, on the schematic, we have # 1, ground, black, as usual. The diagrams are, as I said, not very informative, but terminal 2 bets a black/white, which I believe is the continuous run for the washer. Terminal 3 gets brown/light green, which I think is the intermittent wipe, and terminal 4 gets brown/pink, which should be park.
However, the terminal numbers may be screwed up. The diagram shows no connector number at the wiper motor itself, but four other connectors in line between it and the wiper switch, all with different pinouts. On the last in line, C310, motor terminal #1= its #9; motor #2 = #1, motor # 3 = #8, and motor # 4= #7.
You should be able to sort this out with a test light or meter. Turn on the ignition but not the wiper switch, and whichever wire is live is the park. Turn the wiper switch on, and whichever wire is turned on is for run. When you put it on "wash," that one should turn off, and another one turn on.
93 and up rear wiper wiring LT1XJ OEM Tech Discussion 9 April 6th, 2008 16:08
rear wiper motor dfreeman616 OEM Tech Discussion 0 March 4th, 2006 17:53
Newer wiper motor 2wdxj OEM Tech Discussion 0 March 19th, 2005 14:41
rear wiper motor xjrugger Wanted: Private Party Only 1 January 5th, 2005 12:44
