Old June 26th, 2006, 13:48
WickedWild WickedWild is offline
Home made flares
I'm running 33x13.5x15 Boggers with a healthy offset, already trimmed the fenders and I'm looking for ideas for home made fender flares with 10" of coverage. On the Jeep's maden voyage I hit the first mud hole in 2wd in low (front axle had not locked in yet) and I got 40' rooster tailes and completely covered the Jeep front to back with just the rear tires. With the front tires spinning it's worse. I don't want to just bye them, goes against everything else on the Jeep. I have to keep the total build cost under 1G and so far I'm @ $675. I've read and searched (I prefer to lurk and search as to post) but most I have found are TJ, BW, and Rusties flares. Suggestions?
Sorry I dont have a better pic but this will get you the idea.
Old June 26th, 2006, 13:51
bean8104's Avatar
bean8104 bean8104 is offline
Re: Home made flares
id say your best bet and the cost you are working with... old tires. it works for alot of guys and they'll bend and flex without ripping off on the rocks. you can basically make them as wide as you want and paint them any color you want. they aren't very attractive... but they work
Old June 26th, 2006, 13:56
MrShaft696's Avatar
MrShaft696 MrShaft696 is offline
ha ive been toying with the idea of modifying my stock ones with fiberglass. I plan to cut the stock ones up and use clay to fill in the extension then fiberglass over the clay onto the plastic, sand it paint it, then bolt the mess to the body. It will take alot of time but cost alot less then those expensive bastards, and you can just fix it with more fiberglass .
Old June 26th, 2006, 14:02
OT's Avatar
OT OT is offline
Try baseboard moulding.
Old June 26th, 2006, 14:09
Skullver's Avatar
Skullver Skullver is offline
Still Flailing
This is what I used, sort of hoakey but budget was also my main concern, and at 1/10 the price of bushwackers.
http://www.jcwhitney.com/autoparts/P...=fender+flares
Old June 26th, 2006, 14:23
fordtech's Avatar
fordtech fordtech is offline
try a less 'healthy offset'
Those things are out there!
Old June 26th, 2006, 14:25
Chero-King's Avatar
Chero-King Chero-King is offline
Lawn edging. Cheap and easy, just cut off one of the rounded edges and screw the other one to the fender. It comes in almost any width. and if it rips off, you still got half the roll left.
Old June 26th, 2006, 19:59
XJSpencer's Avatar
XJSpencer XJSpencer is offline
NAXJA Member #1400
Try extended TJ Flares like This
The problem with that is it looks kinda like an H3 from the front.
Old June 26th, 2006, 20:02
OT's Avatar
OT OT is offline
That and they'd be torn COMPLETELY off on my first trail of the day....
But, they're not going on mine, so I'll just
Old June 26th, 2006, 20:03
Menzenski's Avatar
Menzenski Menzenski is offline
Formerly Mambeu
Well, that's a moot point since you don't have any fenders or quarter panels to mount them to in the first place.
Old June 26th, 2006, 20:10
goodburbon's Avatar
goodburbon goodburbon is offline
Nice passenger, specs? Better pics?
Old June 26th, 2006, 21:56
I was originaly thinking Lawn edging but I dont think it's long enough. I have some 225 45 17 tires off of the Z I'll see what that looks like. The rims are 15x10 and any less offset I loose full turn and eat my lower controll arms in the front. The passenger is going to be my wife.
Old June 26th, 2006, 22:19
19CHEROKEE89's Avatar
19CHEROKEE89 19CHEROKEE89 is offline
i may be taken but i still think u have a hott wife...
it has to be the jeep thing workin for ya.
haha sorry man im just playing.
Old June 26th, 2006, 23:33
mike86xj mike86xj is offline
my buddie works at a place that makes conveyer belts, so I got him to get me some 6" wide x 3/8"strips of belt and a pair of T cleats (almost a triangle), I cut the t cleat down the middle (made 2 smaller triangles).
then I used rubber glue and #12 square/robertson screws to attach the 1/2 t cleat to the belt strips, and then screwed the assembled "fender flare) to the fender with more screws
I have the back ones as well just been too lazy to put them on
the best part is it didnt cost me a dammed thing, if your lucky you might be able to get some cut offs for cheap or free
Old June 26th, 2006, 23:40
cLAYH cLAYH is offline
The rear is conveyor belting and the front is TJ extended flares. The TJ flares were fiberglass(Steel horse?) and broke the first season they went on. Now running Rubicon TJ flares held on with Tie wraps so they'll pop before damaging the fender. The rear I have put into many trees and it just pops back out.
Home made SYE drbobxj Advanced Fabrication and Engineering 12 March 20th, 2006 07:40
home made truss D30 Purple Modified Tech Discussion 6 April 17th, 2005 19:57
home made 8.8 e-brake? diabloxj Modified Tech Discussion 9 January 24th, 2005 18:27
Home Made bumper for an XJ? Legacy Modified Tech Discussion 11 June 17th, 2004 05:45
Made it home alive 4ward 2003 NAC Fest @ Paragon, PA 5 June 3rd, 2003 20:24
