00XJ Parts. Steering, T. Body, Mrs, Alt, Skid, Bumpers, Whls D44 Parts.
tcharon
Lake Tahoe, NV
00 XJ Dana 30 open front axle 46K mi. without brakes, SoCal $150. + ship & handling.
00 XJ Chrysler 29 spline 8.25 open rear axle 46K mi. w/ drums & E-brake cables, SoCal
00 XJ Chrysler 29 spline 8.25 open rear axle 46K mi. w/ drums & E-brake cables, SoCal $250 + ship & handleing.
XJ Dana 44 stock axle shafts 30 spline with only 600 mi use, SoCal
XJ Dana 44 stock axle shafts 30 spline with only 600 mi use, SoCal $150
3 XJ 15” steel wheels 5 on 4 ½, 2 w/ tires 215 & 225/75R15, SoCal
3 XJ 15” steel wheels 5 on 4 ½, 2 w/ tires 215 & 225/75R15, SoCal $10 & $15/
One like new 15” factory gray aluminum Jeep Ecco wheel w/unused Goodyear Wrangler RT/
One like new 15” factory gray aluminum Jeep Ecco wheel w/unused Goodyear Wrangler RT/S 225/75R15, SoCal $45 +ship & handeling
00 XJ stock drag link with 46K mi w/ new larger ends
00 XJ stock drag link with 46K mi w/ new larger ends $30 + ship & handling
00 XJ stock tie rod with 46K mi w/ mount
00 XJ stock tie rod with 46K mi w/ mount $20. + ship & handling
00 XJ stock rear drive shaft with 46K mi AW4/231/8.25, SoCal
00 XJ stock rear drive shaft with 46K mi AW4/231/8.25, SoCal $20. + ship & handling
00 XJ stock front bumper red & scratched black ends
00 XJ stock front bumper red & scratched black ends $20. + ship & handling
00 XJ Stock rear bumper mounting brackets
00 XJ Stock rear bumper mounting brackets $5.+ ship & handling
Front Engine skid plate, factory, 00 XJ
Front Engine skid plate, factory, 00 XJ $20.+ ship & handling
00 XJ stock alternator with 46K mi., works great
00 XJ stock alternator with 46K mi., works great $50.+ ship & handling
Stock Side mirrors, R & L, power, black great shape.
Stock Side mirrors, R & L, power, black great shape. $20/ + ship & handling
New Shackle bushings XJ, poly red 2
New Shackle bushings XJ, poly red 2 $4.+ ship & handling
XJ Dana 44 rear Trac-lock limited slip for 4.88 gears, only 600 mi
XJ Dana 44 rear Trac-lock limited slip for 4.88 gears, only 600 mi $30.+ ship & handling
00 XJ 4.0L throttle body
00 XJ 4.0L throttle body $50.+ ship & handling
Dana 44 rear brake backing plates, wheel cylinders w/ shoes & E-brake cables from 89
Dana 44 rear brake backing plates, wheel cylinders w/ shoes & E-brake cables from 89 XJ, SoCal $20. + ship & handling
Re: Dana 44 rear brake backing plates, wheel cylinders w/ shoes & E-brake cables from 89
sent you a pm
Mod Edit: About D44 Brakes.
Re: 00 XJ Dana 30 open front axle 46K mi. without brakes, SoCal $150.
I assume its HP?
BTW, sorry I havent come to see you at the office lately. You aren't in network. :)
Josh
Mod Edit: About Dana 30.
Re: One like new 15” factory gray aluminum Jeep Ecco wheel w/unused Goodyear Wrangler RT/
I'll take it.
Do you mind sitting on it 'til I can make it down that way?
Sequoia
PS - you're selling an awful lot of stuff, are you parting out?
Mod Edit: About Ecco Wheel
