Old May 22nd, 2006, 22:30
TheBlueSub's Avatar
TheBlueSub TheBlueSub is offline
maybe the death wobble
i searched and think it may be the dreaded death wobble but....
i did a 3" lift a few weeks back and put on 31"s a week ago and tonight i went and played around (mud,trails)so i haven't had a problem till now i am confused
i left and got back on the road and at about 45-50 it wobbled and quit when i was over 50 and below 45 i havent looked under the truck and i gotta head to work early and wont be able to look till tommorow night so i was wondering if anyone had this problem after a similar situation??
p.s.-i ordered a tcd this morning before this happened and a new trac bar
please help
thanks
Old May 22nd, 2006, 22:39
CanMan's Avatar
CanMan CanMan is offline
Re: maybe the death wobble
You said you played in the mud. When I used to, I would experience the same deal as you. I had so much mud caked on one of the front tires, especially on the inside of one. I pressure washed it, and the wobble went away.
Id look for that first, then go from there.
Old May 22nd, 2006, 22:42
Dirt's Avatar
Dirt Dirt is offline
If you think you may have death wobble...
YOU DON'T!
Clean the mud off the wheels.
Old May 22nd, 2006, 22:44
TheBlueSub's Avatar
thanks i love you guys
im sorry i will crawl back into my dark hole and pretend like nothing happened
i will post some pics
Old May 22nd, 2006, 22:46
Shomsky462's Avatar
Shomsky462 Shomsky462 is offline
death wobble isnt called DEATH wobble for fun and games. it doesnt just shimmy. it starts to wobble then gets proggresively worse in a matter of about 2 seconds until your whole front end jerks around insanely fast and if you look out your window while its happening its CRAZY!!!
i get it a lot a lot. tighten down your trackbar every once and a while and tighten your upper and lower control arms and lug nuts because they might want to shimmy right out and you could lose your wheel like me...
go to www.google.com and type: death wobble click on the first one and read the whole thing.
hope this helps
-Ryan
Old May 22nd, 2006, 22:48
Shomsky462's Avatar
aaaahhhh crap!! why didnt i think of the good ol' 5 pounds of mud gathering in one spot on your rim and throwing it off balance like crazy.
scrape it all off and ul be all good
Old May 22nd, 2006, 22:54
TheBlueSub's Avatar
this is what the wheels look like i dont have the action pics yet
Old May 22nd, 2006, 22:56
Jonnyjpr's Avatar
Jonnyjpr Jonnyjpr is offline
Yea, you need to clean those rims and inside of your tires off, not to mention the steering too.
Old May 22nd, 2006, 22:59
TheBlueSub's Avatar
but why does it only do it between 45-50??
i will hose r in the morning
Old May 22nd, 2006, 23:03
CanMan's Avatar
All that weight being slung around at a faster speed will do it. Your speedo may be off too, so it could be less MPH.
Id pressure wash it, since when I hosed my wheel off, it did very little.
Old May 22nd, 2006, 23:07
TheBlueSub's Avatar
it is off 4-5 mph and i will scrub and spray the entire heep thanks for the help
good night
Old May 23rd, 2006, 07:56
Roxtar's Avatar
Roxtar Roxtar is offline
YOU DON'T!
Perfectly put.
There is no such thing as, "I might have DW"
If it happens you WILL know it.
Old May 23rd, 2006, 20:27
TheBlueSub's Avatar
o this was a shaking the ash tray open and the cd's out of my visor holder and the front end was almost hopping and i had the death grip on the wheel and it was all better when i washed it today
has anyone had a problem with there tranny leaking at a higher RPM?? its not my front or rear seal or my pan gasket any body else had this
thanks
How To: Fix Death Wobble Badcop Modified Tech Discussion 24 December 15th, 2005 06:12
Death wobble Brian Felts Modified Tech Discussion 11 August 27th, 2004 09:41
xj death wobble big cherokee Modified Tech Discussion 12 February 9th, 2004 19:40
Need Death Wobble help… gixer Modified Tech Discussion 9 November 5th, 2003 23:07
death wobble sford Modified Tech Discussion 6 October 26th, 2003 07:09
