Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > North Atlantic Chapter > NAC Classifieds
NAC Classifieds ONLY Local Sale Items here.
Old April 2nd, 2006, 13:24
tighttrailxj tighttrailxj is offline
parting out , 1990 Renix 4.0
I am stripping down a 1990, 4.0L, AW4, 242, light tan full power interior.
Things of interest: 1) AW4 (21 spline output) modified by Level 10 transmissions of NJ, about 5,000 miles on it, custom clutches and converter locks at about 850rpms, great for street and trails, Paid $2400 last June.
2) hack n tap 242 sye done at a machine shop, with a rubicon express driveshaft
3) full power, tinted windows, newer window motors, on all four dours, dark blue with alot of "pine striping"
4) hood and hatch
5) multiple sets of tail lights
6) renix 4.0 with 84,000 miles, multiple sets of all underhood sensors, can hear run before we pull it out. New water pump, alternator, tune up ( all within the past 2 weeks)
8) rubicon express drop bracket kit, adjustable upper arms, fixed lowers, I will power coat the brackets and supports black so they will look better than new ones.
I am basically stripping the entire truck and keeping the axles, suspension, bumpers, and some other stuff. I live in Staten Island.
P.S. that screen name should now be in RED
Old April 2nd, 2006, 16:07
Menzenski's Avatar
Menzenski Menzenski is offline
Formerly Mambeu
Re: parting out , 1990 Renix 4.0
How much are you looking to get for the engine?
Old April 2nd, 2006, 18:55
Motor is in great condition, I have run synthetic fluid in it since 42,000 miles. It has not been run hard, EVER. On highway trips, I keep RPM's about 2,300. It has many new accessories, air cond. works great. It also has an aluminum valve cover. I will give you the motor, all accessories, intake, exhaust, all computers, sensor, perfect radiator, etc. for $500. Basically, anything related to the motor goes with it. I will pull it out, or you can come and hear it, then we can pull it.
Old April 2nd, 2006, 18:56
katarn444 katarn444 is offline
I am looking for a manual chrome driverside mirror, I am guessing that yours are power but wanted to make sure. Thanks
K
Old April 2nd, 2006, 19:09
yes, they are power
Old April 2nd, 2006, 19:18
xj87's Avatar
xj87 xj87 is offline
NAXJA Member #952
how much for the 242 and driveshaft
Old April 2nd, 2006, 19:30
do you want the entire case? I bought it about 4 months ago, New old stock from a dealer. I had to pull the case apart to change the input shaft from 23 spline to the current 21 spline. ( I still have the 23 spline shaft) I think that the linkage got a little tweaked last trip. So I can't tell you if the case is for sale untill I split it and check the internals. I think it is fine, but I won't sell it untill I check it out. I will sell the SYE and CV driveshaft. I paid $300 for the shaft and $150 for the SYE. I will sell the pair for $175. thanks
Old April 3rd, 2006, 01:32
swbooking's Avatar
swbooking swbooking is offline
Is the ECM for sale? How Much?
Old April 3rd, 2006, 07:09
I will only sell the ECM if the buyer for the engine does not take it. I will PM you in that case, thanks
Old April 3rd, 2006, 16:57
XJ Samo's Avatar
XJ Samo XJ Samo is offline
How much for trans?
Old April 3rd, 2006, 18:17
CMNCHE's Avatar
CMNCHE CMNCHE is offline
How much for the adj. upper arms? Will you ship?
Old April 3rd, 2006, 18:47
pm's sent
Rate This Thread:
anyone in cali swap a HO in a renix yr and pass smog like its a renix? RWKHausSupply Modified Tech Discussion 8 January 30th, 2006 14:55
Parting out 1990 XJ seanR Midwest Chapter 22 June 5th, 2005 22:43
Parting out 1990 MJ Pioneer MJ1990buildup For Sale: Private Party Only. XJ ITEMS ONLY 28 March 24th, 2005 19:36
NC: Parting out 1990 XJ laredo Lifted, etc Tim88XJ For Sale: Private Party Only. XJ ITEMS ONLY 15 October 2nd, 2004 19:46
1990 4.0 Renix exhaust manifold georgemu Wanted: Private Party Only 4 December 24th, 2003 00:53
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
