Old August 2nd, 2003, 06:52
old88xj old88xj is offline
Replace or Rebuild?
There has been several postings as to my motor woes. Scarred crank, spun rod bearing, several spun main bearings. Along with some blow by.
My question is what would you guys do? Replace the crank and spun bearings and deal with the blow by later? Replace the motor? or pull the motor and have it rebuilt at a machine shop? I have never had to deal with this before, and it doesn't have to be a daily driver so time is not of the essence. I am some what mechanically inclined but not to the point of doing the crank job myself. crank job at a shop comes in at the price of $1300. Where as i can get a Recon motor for $920 an have it installed for $400, and have not priced a rebuild yet. But was looking for some good opinions
BTW 88 4.0 auto 115K
TIA
Daniel
Old August 2nd, 2003, 08:58
Jared's Avatar
Jared Jared is offline
So, pretty much what you're saying it that every major engine component that you have (crank, rods, pistons, rings, etc....) is crap! I don't see how this is still a question.
If you have to replace/refurbish EVERYTHING, just find the cheapest route and DO IT! If the cheapest route is a new motor, do it. If the cheapest route is a total rebuild, do it.
Bad compression sucks! Reduced power, increased emissions, increased fuel consumption, and burning oil are all CRAP to live with. As long as the engine comes out, do it right and fix the tired old top end.
Having an engine that runs like a top is great. So is the confidence that comes with knowing your engine isn't going to blow up sometime soon. I say that fixing it top to bottom is the only way to go!
Old August 2nd, 2003, 20:33
Hmmmmmmmmmm
replace the door?? asatxj OEM Tech Discussion 2 December 8th, 2003 10:38
2.5L Rebuild advise...... Ghost OEM Tech Discussion 7 July 16th, 2003 10:15
engine problems, replace? rebuild? stroke? DJ6624 Modified Tech Discussion 8 June 16th, 2003 04:47
4.0 Rebuild Questions Josh Modified Tech Discussion 5 March 31st, 2003 09:28
CJ Rebuild progress update... Skorpyo North Atlantic Chapter 1 November 20th, 2002 14:59
