Old July 30th, 2003, 20:13
dgmachinist's Avatar
dgmachinist dgmachinist is offline
I have not Confirmed, or I used a BAD email Addy
Driveshaft lengths
I am looking for the OEM lengths for an 1988 XJ driveshaft. (both front and rear) I am thinking of swapping out my 242 t-case and putting in a 231. The Jeep is a 4spd auto, I'm not sure of the axles, but I think that they are Dana 30's??? they are not disco type. I was told by one person that I would have to get new shafts, then another told me that the ones I had would suffice....
Seth
Old July 30th, 2003, 20:17
ChuckD's Avatar
ChuckD ChuckD is offline
I concur with the friend.
Old July 30th, 2003, 21:05
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
The axles are not Dana 30s. The front is, but the rear will be either a Dana 35 (most likely) or a Dana 44 (not very likely). The D44 has a longer pionion and takes a correspondingly shorter driveshaft.
I'm currently working on an '88 with Dana 35 axle and 242 transfer case. I'll try to remember to measure the rear shaft length for you when I'm in the garage tomorrow.
BTW -- check the North Atlantic Chapter forum, we're planning a get-together in Maine. Hope to see you there.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old July 31st, 2003, 01:32
CheapXJ's Avatar
CheapXJ CheapXJ is offline
there's no difference in case length between a 231 and a 242.
Old July 31st, 2003, 04:15
Well, my 88 currently has the 242. The reason that I want to replace it is because it's cracked. I just happen to have a 231 sitting in my shed. I do disagree however on the case length. I think that the 231 is .150 thousands (about 5/32nds) longer. But, I could be wrong....
Seth
Old July 31st, 2003, 07:06
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
At one point I had a 242 and 231 Front shafts and the rear from a 242. The fronts were the same length. And if memory serves me the rears were the same also. I still have the rear shaft from a 242.
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old July 31st, 2003, 10:21
ECKSJAY's Avatar
ECKSJAY ECKSJAY is offline
Water is dirty
Here's info on the front shafts.
http://www2.dana.com/pdf/J321-CV.PDF
Old July 31st, 2003, 13:27
CheapXJ's Avatar
Seth
there no SIGNIFICANT difference that would necessitate a change in driveshaft length.
better?!?!?
Old July 31st, 2003, 20:26
Much! thank you for all your advice! I should be able to tackle the swap this weekend perhaps. I'll let you know how it goes.
Seth
My '85 needs a Double Cardan driveshaft conversion, what do I need to get? jstandle Modified Tech Discussion 16 June 7th, 2005 23:16
Front Driveshaft Rebiuld $$$?? cherokee89 OEM Tech Discussion 10 December 10th, 2003 15:04
Simple Rear Driveshaft Question OILBURNER Modified Tech Discussion 16 October 29th, 2003 14:00
The driveshaft vibe Amund2 Modified Tech Discussion 2 August 25th, 2003 09:38
driveshaft length thompson97 Modified Tech Discussion 5 May 27th, 2003 17:00
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
