Old March 11th, 2006, 07:08
CGEMC's Avatar
CGEMC CGEMC is offline
Power steering pump reservoir
I was trying to remove the return hose from my PS pump when the fitting snapped off the reservoir. I found the reservoir seperately from several suppliers, but its listed for '91-'96 4.0. Does anybody know if this will work on a '97 4.0. The part numbers for the pump are the same. Since my steering worked fine except for the leaky reservoir I'd like spend $25 instead of $150ish. I can't post attachments for som reason, so I'm including a URL of a good picture.
http://www.just4jeep.com/catalog/product1060.html
Thanks for your help.
Ron
Old March 11th, 2006, 13:08
BIGSLVRXJ's Avatar
BIGSLVRXJ BIGSLVRXJ is offline
Re: Power steering pump reservoir
I think it will fit directly, the only thing is you might have to get a little more hose or cut a little off of your existing hose to get it to fit. Wait for a couple more opinions before you take my word for it though.
-Collin
Old March 11th, 2006, 15:01
CGEMC's Avatar
I pulled my reservoir off to get a better look and I also think it is the same part. I have to order it since no one has it locally. While I have it apart I plan to flush the system, and replace the return hose since I had to cut it to get it off the fitting. The fitting did'nt break so much as it failed at the connection to the tank. You can look at it and tell it was glued on from the factory. No splintering, no deformation of the surrounding plastic, nothing but a perfectly round hole where the fitting used to be.
Old March 11th, 2006, 15:02
CGEMC's Avatar
Edit for double post
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 13:38
Brake Fluid in the Power Steering Reservoir RedBluff OEM Tech Discussion 4 September 16th, 2004 22:43
Gluing Power Steering Fitting on Reservoir PaulJ OEM Tech Discussion 2 August 21st, 2004 08:58
Glueing Power Steering Reservoir return tube L92XJ OEM Tech Discussion 4 March 19th, 2004 11:15
Power steering pump is going out ... What to buy? Big Bear Modified Tech Discussion 17 December 19th, 2003 11:29
