Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
Old March 1st, 2006, 08:35
Smittty9785's Avatar
Smittty9785 Smittty9785 is offline
1990 xj serpentine belt tensioner location?
ok this is sad i just dont understand. well i lost my diagram about the serpentine belt route, i managed that. But now i cant find the damn tensioner to put a new one back on? any suggestions?
Old March 1st, 2006, 09:51
5-90's Avatar
5-90 5-90 is offline
Re: 1990 xj serpentine belt tensioner location?
Power Steering Pump. There are two bolts on the back, the top bolt on the front, and a nut on the slider stud - all take a 13m/m wrench.
Once you've loosened those, put a 1/2" socket on the head of the adjuster bolt (runs crosswise under the pump, you may want to remove the airbox to access it easier) and play with that bolt - LOOSEN to remove tension, TIGHTEN to increase it.
Tighten all four bolts/nuts when you're done. The two on the back will certainly want a wrench, and you don't have to loosen them very far anyhow - so a socket really isn't needed for the adjuster bolts - just the crosswise slide bolt.
Be careful you don't crack the "knuckle" that holds tension on the pump - it's sintered, and I haven't been able to start making new ones out of wrought stock yet...
Old February 7th, 2009, 15:26
mpzg90's Avatar
mpzg90 mpzg90 is offline
Holy crap i just spent like half an hour lookin for that last bolt on the back your a life saver, lol. thanks!
Rate This Thread:
Belt tension on Serpentine belt? Planetcat OEM Tech Discussion 36 July 9th, 2009 23:58
Broke belt tensioner bolt...... Fred85 OEM Tech Discussion 11 February 13th, 2006 19:57
Serpentine BELT Gianfranco Provenz OEM Tech Discussion 2 December 15th, 2005 08:09
belt tensioner bolt... dizzymac OEM Tech Discussion 5 August 5th, 2005 16:10
belt tensioner jeep_cj8 OEM Tech Discussion 3 July 11th, 2003 08:54
