Old February 12th, 2006, 07:40
Fred85's Avatar
Fred85 Fred85 is offline
Broke belt tensioner bolt......
I figured i would do this, but i broke the big long 15mm tensioner bolt for the belt......it snapped in half right at the idler pulley, but the pulley is still held tight by the other end
what all do i need to go buy now? lol
it doesn't seem like i'll need a whole new ps pump bracket but ya never know.....
Old February 12th, 2006, 08:28
RTicUL8's Avatar
RTicUL8 RTicUL8 is offline
Re: Broke belt tensioner bolt......
That's the first time I heard of someone breaking that bolt.
What year XJ?
It's a 13 mm socket, right?
You said "I figured i would do this"
Why? Were you pounding it with your sledgie?
Got a salvage yard near you?
Old February 12th, 2006, 08:32
Fred85's Avatar
That's cause i'm an idiot.......lol
anyway, nope a 15mm bolt
i just can't tell if i need to get a new idler pulley or a new power steering pump bracket, and i'm not sure if the new bolt comes any of those
Old February 12th, 2006, 08:37
RTicUL8's Avatar
What year? engine?
Old February 12th, 2006, 08:45
Fred85's Avatar
whoops, sorry.............2001, 4.0
i made the mistake of not loosening the idler pulley bolt before i tried to tighten the belt and i snapped the belt tensioner bolt, i guess it slipped my mind to loosen the idler pulley bolt
i'm worried i'm not gonna be able to find that long bolt anywhere
Old February 12th, 2006, 11:21
Calata Calata is offline
Since you state that you never loosened the idle pulley bolt in the first place, leave it alone for now. Order a new bolt from the dealer. It's $7.18 at http://www.chryslerpartsdirect.com/.
Old February 12th, 2006, 15:36
Fred85's Avatar
i cannot find the bolt on that site to save my life, i've looked in almost every category
Old February 12th, 2006, 17:52
PM me your email address and I'll try to better help you. Or just call the dealer. P/N for the bolt is 6503198. If you also need the collar that the bolt goes into, it's p/n 53010149.
Old February 13th, 2006, 12:06
HoratioTheJeep's Avatar
HoratioTheJeep HoratioTheJeep is offline
Red face Re: Broke belt tensioner bolt......
Fred85: just to try to make you feel better, I should let you know I did the same thing.
Old February 13th, 2006, 14:11
barlowjames barlowjames is offline
I broke the collar part on mine.
I changed the belt and went to tighten it. The threads on the bolt, near the head, were rusted and it went into the collar and split it.
Now I just use a pry bar between the PS body and engine and tighten the bolts. Seems to be working so far with no problems.
Old February 13th, 2006, 20:44
Fred85's Avatar
total for both parts from dealer is $14, not that bad i guess
Old February 13th, 2006, 20:57
Brendan_91XJ's Avatar
Brendan_91XJ Brendan_91XJ is offline
NAXJA Member #1163
Broke the tightening collar myself the same way...
Kejtar with his master welding skills took two nuts and welded them together, I think it is stronger than the original.
Upper Shackle Bolt NUT BROKE redyouch Modified Tech Discussion 5 August 1st, 2005 17:05
Upper Shock Bolt Broke, My Solution PstrKd4BrthCntrll OEM Tech Discussion 3 May 16th, 2005 20:41
Serpentine belt / ps pump whine... Creighton OEM Tech Discussion 5 October 21st, 2004 18:55
Broken bolt, now what? I'll tell ya what... ChuckstrPT Modified Tech Discussion 7 May 3rd, 2004 06:23
metric bolt strength sarvermr Modified Tech Discussion 5 March 8th, 2004 12:14
