Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Tow Rigs and Trailers
Tow Rigs and Trailers Hey, not all of our Jeeps are great on the highway. Post here for tech related to getting your XJ to the trailhead.
Old February 11th, 2006, 14:51
crazy4mopar's Avatar
crazy4mopar crazy4mopar is offline
Vortec misfire
Hey guys
I'm getting a deal on a 99 vortec 4.3 for a new project. It has 21k miles on it. It has a misfire on the #5 cylinder. We have changed everything we can think of, 3 computers, wiring harness, all injectors, all sensors, 2 fuel pumps, wires, cap, 2 distributors, the only code that comes back is #5 misfire detected. It happens at about 2800 rpm. Would a bad valve spring make it misfire?
Any ideas would be GREAT!!!
Old February 11th, 2006, 15:46
CMNCHE's Avatar
CMNCHE CMNCHE is offline
Re: Vortec misfire
Could be a valve spring. Must be mechanical given all that you have replaced. Cam lobe wiped out??? Remove valve cover and see if the valve is opening when you spin the engine by hand.
Old February 11th, 2006, 17:37
mikecooper mikecooper is offline
Re: Vortec misfire
Did you check the idle air control and does it have an adj tps?
Old February 13th, 2006, 19:54
chris1044 chris1044 is offline
Re: Vortec misfire
Try taking a propane torch - not lit, just so the propane comes out of it, and put it by the intake manifold gasket by cylinder number five while the things in the range that it typically misses. If the miss goes away, the intake gasket is bad. If you're ballsy you can use carb clean
I've seen intake gaskets on those things have just a pin hole leak that will cause a lean miss under higher RPM.
It's possible for the valve spring to make it miss, but that'd be way way worn out and would probably cause it to miss under other conditions as well.....the cam lobe theory could hold true for a partially worn lobe, but I'd find it hard to believe only one lobe is worn and the others are fine
Rate This Thread:
cylnder misfire? etaniyani OEM Tech Discussion 28 January 20th, 2006 19:56
CE light=1st Cyl Misfire zfinger OEM Tech Discussion 2 December 9th, 2005 16:21
'01 XJ Misfire Questions BIGSLVRXJ OEM Tech Discussion 5 October 23rd, 2005 10:39
CO: NV4500, Vortec V6, and Lots More! *Updated 7/8* Zed Mikey For Sale: Private Party Only. XJ ITEMS ONLY 6 November 19th, 2004 22:43
occasional misfire markpr OEM Tech Discussion 2 April 3rd, 2004 15:41
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
