Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Intermountain Chapter
Intermountain Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old February 8th, 2006, 09:13
grandpaxj's Avatar
grandpaxj grandpaxj is offline
5.3 vortec
I know that there is alot of hard core jeepers out there, and I have built over 50 4x4s in the last 40 years but I'm thinking of doing something different with my XJ. I have in my possession a brand new 5.3 vortec and tranny with everything I would need to make a power train transplant. the pros I see is that the 5.3 weighs 150 lbs. less than the 4.0 and it has about 145 more horses than the 4.0. I think that I've covered the complete change over in my mind from alum. rad., to gauges, to exhaust and computer. Maybe I'm putting neck on the chopping block now by asking for anyones intelligent thoughts here but what do you think?????? Jerry
Old February 8th, 2006, 09:26
k9lowe's Avatar
k9lowe k9lowe is offline
NAXJA Member #1135
Re: 5.3 vortec
With this kind of experience you need to work on my rig...and concerning your rig you can do what ever you want. I think that would turn out awesome.
Old February 8th, 2006, 10:05
ACE's Avatar
ACE ACE is offline
Re: 5.3 vortec
If you think you could make it work Jerry, go for it. Then I'll come up and break it in for you.
With all of the weight you're carrying around in the XJ, the 4.0 probably feels like a pig. What about just throwing a blower on the 4.0? By the time you do all of the custom work needed to house the 5.3, you will have probably spent close to the cost of a good supercharger.
Let us know if you decide to take it on. We could have some wrenching parties out at the shop.
Old February 8th, 2006, 10:17
grandpaxj's Avatar
Re: 5.3 vortec
the best by on a super charger I can get is $3500 and I can do all this change over for less than that and I can sell the old 4.0 with only 62,000 miles on it to also recoup more money. the 4.0 has banks ceramic headers, air raid tube and throttle spacer K& N air filter. Jerry I would love to have shop days again, it just takes 6 paying students from the club to make it happen.
Old February 8th, 2006, 19:26
XJSpencer's Avatar
XJSpencer XJSpencer is offline
NAXJA Member #1400
Re: 5.3 vortec
My '99 Silverado has the 5.3 Vortec and it's amazing in the half ton. It would be insane(incredible) in a Cherokee. Good idea.
Old February 8th, 2006, 20:17
DrMoab's Avatar
DrMoab DrMoab is offline
Re: 5.3 vortec
The big problem is cooling. If you can whip that problem you will be ok.
Old February 8th, 2006, 20:22
DaveW's Avatar
DaveW DaveW is offline
Re: 5.3 vortec
Jerry is going to need one of those cowl induction hoods. They look good and should help the cooling.
Old February 8th, 2006, 20:24
DrMoab's Avatar
Re: 5.3 vortec
More then that...From what I have read, even a 3 or 4 core aluminum radiator with twin high CFM fans are not enough to cool a V8 in a jeep
Old February 8th, 2006, 20:40
JeeperG's Avatar
JeeperG JeeperG is offline
Re: 5.3 vortec
More then that...From what I have read, even a 3 or 4 core aluminum radiator with twin high CFM fans are not enough to cool a V8 in a Cherokee
Fixed it for ya.
Old February 8th, 2006, 20:46
DrMoab's Avatar
Re: 5.3 vortec
Originally Posted by JeeperG
Fixed it for ya.
thats what I meant to say
Old February 8th, 2006, 21:32
stewie's Avatar
stewie stewie is offline
Re: 5.3 vortec
eh, just go with out a hood! show off the unique mod.
Old February 8th, 2006, 21:51
Jared's Avatar
Jared Jared is offline
Re: 5.3 vortec
I would pass. I worry enough about the unibody as it is, more power could only put more strain on things.
On the other hand, if the body held up, and the 40-80 hours of work and headaches were worth it to you (which they wouldn't be to me) it could be a sweet, unexpectedly fast/powerful rig. I'm also seeing a HUGE red flag in the cooling dept. The problem with cherokees, as I see it, is their small grill opening. They cannot accept a large enough radiator without serious modifications. I'd recommend removing the front crossmember and replacing it with a stout front bumper or equivalent crossmember which allows at least 3-4 more inches of exposed height for the radiator. Adding more cores to a radiator is pretty useless after 2 or maybe 3 cores - but adding square inches makes a huge difference.
But seriously, just make sure you understand what your final product will be. You'll have an XJ, with a gigantic amount of do-it-yourself wiring under the hood and dash, probable cooling problems, and a shoehorned-fit awesome V8 under the hood, and likely a chopped/fabbed trans tunnel/console/carpet. All this for only a few months of your spare time and several hundred dollars in custom and conversion parts. But hey, it would run good.
Jared
Old February 8th, 2006, 22:24
DrMoab's Avatar
Re: 5.3 vortec
Admit it Jared...you are just a cheap-skate.
Old February 8th, 2006, 23:14
Jared's Avatar
Re: 5.3 vortec
Yes, I am. Absolutely, with no shame, I am a cheapskate.
But I guess when I look at XJ's, I see limits. It's one heck of an easy platform to make a very capable and still family friendly trail rig for not a lot of money. BUT - it has no frame. Eventually, XJ bodies self destruct when used hard off-road. I want a rig that can catch 5 feet of air and not flinch. So, I look at my XJ's as a great, very worthy stepping stone that I'll stand happily on until I can afford a higher-dollar rig - something that can stand up to high speed desert racing stuff, which is basically my favorite thing in the world to do, even more than rock crawling. So to me, building an XJ to the extent of dropping in a 275 HP V8, with heavy duty axles and killer suspension and a full cage just doesn't make sense. While XJ's CAN be built to handle incredible stress on the body with a full cage, why do it? Just start with a boxed frame and abuse it.
I've always said that it's worth building an XJ with a nice lift, some trimming, skids, bumpers etc., but doing much more than that is really going beyond what XJ's are designed to handle without unreasonable modification.
Anyways, rant over. It's your rig and your time/money. I'd run for your life from a project like that, but it would still be "cool".
Jared
Old February 10th, 2006, 21:58
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Re: 5.3 vortec
Jerry, if anyone has the resources to pull this off, you do. I say, go for it. Jared's on the right track with the cooling part, fab a tube crossmember to tie in the unirails behind the bumper and make your custom radiator taller for more surface area. This should also allow you to run a larger set of electric fans.....perhaps some of the dual shrouded F.A.L setups will work?
Don't forget to add a crossmember under the pan to tie the rails in and brace the trackbar.....this is needed for any stock XJ , and helps the motor mounts live longer too.
Speak the Truth-Question with Boldness-Speak without fear.
Rate This Thread:
AZ: Parting XJ project (Vortec drivetrain, built axles, etc) Blatant For Sale: Private Party Only. XJ ITEMS ONLY 5 February 20th, 2007 00:29
vortec V6 revised SWAPPING88 Modified Tech Discussion 1 September 16th, 2005 08:11
vortec v6 engine swap writeups? SWAPPING88 Modified Tech Discussion 1 August 23rd, 2005 05:22
4.3 Vortec and 700r4 Chris J. For Sale: Private Party Only. XJ ITEMS ONLY 0 February 13th, 2005 12:13
CO: NV4500, Vortec V6, and Lots More! *Updated 7/8* Zed Mikey For Sale: Private Party Only. XJ ITEMS ONLY 6 November 19th, 2004 22:43
