Old January 9th, 2006, 15:53
jeepurnaz's Avatar
jeepurnaz jeepurnaz is offline
Talking Side Window Replace
2000 XJ. Has anyone ever replaced the quarter glass in a 2dr. XJ ?
I mean the large ones on each side behind the doors.
I want to put in ones that slide open a bit.
Thanx for any help.
Old January 9th, 2006, 16:44
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Re: Side Window Replace
The quarter windows are the nice old fashioned non-glued type, and should be pretty easy to replace. To remove an old one, after removing any extra pressed-in plastic molding, you start by getting inside and pushing the inner lip of the gasket past the glass toward the outside, and gradually pass that lip to the outside of the pinch weld in the body as you push outward on the glass. Start at the top, so that the glass is still held at the bottom and doesn't just plop out on the ground. If you are sure you have a good gasket to spare, the quick way to get it out is to take a utility knife and cut the gasket. This guarantees that you don't stress the glass. Two people are handy here, but if you're careful you'll see when the point comes when you can step outside and just pull the glass the rest of the way up and out.
To replace, you put the gasket on the glass first, then put a long piece of thick string into the groove that goes over the pinch weld, long enough so that the ends of the string cross each other. Again it helps to have two people doing this job. You then hold the glass against the car body from outside, and carefully pull on the string to pull the inside flange of the gasket inside. If you do this right, it is very quick and easy. The hatch glass is easier to do single handed, because you can rest the glass on the open hatch and just pull the string.
Old January 9th, 2006, 19:25
hman333's Avatar
hman333 hman333 is offline
i just replaced my passenger side with lexan after busting the old one out at tellico, it is not too bad
Old January 10th, 2006, 09:56
jeepurnaz's Avatar
Talking Re: Side Window Replace
Thanx for the help.
Inner seal for front axle: One side only? jlex OEM Tech Discussion 4 August 15th, 2005 12:20
Driver's Side Window Regulator 99' surfmon Wanted: Private Party Only 1 February 15th, 2005 05:26
Wanted: 96 Cherokee rear driver side window 96JEEP Wanted: Private Party Only 7 February 13th, 2005 19:11
Window Regulator, Motor only...... Ghost For Sale: Private Party Only. XJ ITEMS ONLY 0 December 6th, 2003 11:41
Passenger side water leak... Patriot OEM Tech Discussion 2 August 26th, 2003 22:53
