Old December 22nd, 2005, 15:50
JeepXJ93 JeepXJ93 is offline
Disabling the 4.0?
Me and some buddy's decided to mess around w/ one of my buddies so we decided to prank her in regards to the newer jeep she just bought, its a 98 classic. We were thinking steeling the wheels and putting it on blocks, but its too cold and that would take too long, and we dont want to give her a heart attack. Then someone suggested drain the fuel out and and show up w/ her gas laughing and recording her face...but we cant seem to snake the hose down far enough...anyone have any ideas? We were thinking disconnect the battery cable but she's too smart and she'd see that...any ways to disable to engine w/out hurting it? TIA
Old December 22nd, 2005, 15:54
87manche's Avatar
87manche 87manche is offline
Re: Disabling the 4.0?
pull the fuel pump relay. It will crank but won't start. Good ghetto security system if you're leaving it parked for a long time somewhere like the airport.
Old December 22nd, 2005, 16:24
Only In A Jeep XJ's Avatar
Only In A Jeep XJ Only In A Jeep XJ is offline
Newer fuel tanks have a screen in them that prevents removing fuel from the filler neck. also the plug for the pump is just at the front of the tank easy to pull if doors are locked.
Old December 22nd, 2005, 16:29
5-90's Avatar
5-90 5-90 is offline
Pull the fuel pump relay, the start relay, or the distributor rotor - the latter is the least visible, but requires underhood access.
Something you can do from underneath? Pull the SMALL lead off of the starter (the solenoid trigger) and insulate it so it can't ground out on anything. Turning the key should work normally with the exception of the starter turning. You do want to make sure you get the loose end thoroly insulated - having it "spark out" on a chassis ground is nothing nice.
Another idea - find a section of rubber fuel line, and install a clamp. Easy to do, easy to remove, and won't harm anything.
Or, pull the power to the fuel pump - should be back somewhere near the fuel tank.
5-90
Old December 22nd, 2005, 16:33
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
By merely pulling the ASD relay, you disable everything in the PCM. I use that trick as my poorman's anti-theft device whenever I park in questionable areas.....
Member #133
Kleptomaniacs help themselves, because they can't help themselves......
Old December 22nd, 2005, 17:47
langer1's Avatar
langer1 langer1 is offline
Pound a potato up her tail pipe.
Old December 22nd, 2005, 17:53
casm's Avatar
casm casm is offline
Not so keen on the potato trick. PITA to remove if done right (or wrong, depending on your point of view), and can cause damage while being applied. I plead the 5th on how I know this, and agree with 5-90 on just going for minor nuisance-type stuff.
Old December 22nd, 2005, 17:54
Pogiboy's Avatar
Pogiboy Pogiboy is offline
How about remove her hood? She would be able to drive it, but her face would be really red!
Old December 22nd, 2005, 18:00
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
i would also agree with unplugging the fuel pump, its quick and easy espesially if its locked.
Old December 22nd, 2005, 18:02
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
Or, instead you could buy her a membership to , and then help her pick out a nice lift and some tires and help her install it so she can run over Hondas!
Dirk DeYoung--Member #176--National Vice President, SEC President
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2013 WKII (SUZIE)...2006 XK (TOW RIG)
Old December 22nd, 2005, 19:25
Dragline Dragline is offline
We're still talking about the Jeep right??
Old December 22nd, 2005, 19:33
Zoro Zoro is offline
If you have underhood access try switching a couple of the plug wires arround at the distributor cap, it will run but run like crap and it's easily fixable.
Old December 22nd, 2005, 19:55
natep1's Avatar
natep1 natep1 is offline
Zipties on the driveshaft are far better than any no start prank in my book.
Annoying as heck & you won't want to crawl underneath until you get back home to remove them.
Old December 22nd, 2005, 20:12
shortxjdoug's Avatar
shortxjdoug shortxjdoug is offline
i'd just go for the wheels, revenge is a dish best served cold, but thats just me... but if you want to go the quiet route disconnect the starter, because the look on her face when everything else works except the starter would be priceless
Old December 22nd, 2005, 20:19
MyJeepXJ's Avatar
MyJeepXJ MyJeepXJ is offline
Is that what they call 'em now days? I still call mine Johnson. :-)
a 4.0, is a 4.0, is a 4.0? JnJ Non-Tech / Off Topic 2 October 24th, 2005 04:59
90 4.0 vs 97 4.0 water pump question tmacie OEM Tech Discussion 9 October 16th, 2005 20:38
Swap 4.0 for 4.0HO DADDJP Modified Tech Discussion 2 August 18th, 2005 19:46
4.0 HO head, and intake 96 XJ Fletch For Sale: Private Party Only. XJ ITEMS ONLY 4 March 21st, 2004 16:48
Disabling ABS Aggie05 OEM Tech Discussion 2 August 1st, 2003 10:50
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
