Old December 14th, 2005, 22:00
Harvo's Avatar
Harvo Harvo is offline
Fender Cutting Questions Answered (at least mine)
I read probably all the posts on cutting fenders, but there were still a few unanswered questions for me. I figured what the heck... I have to cut anyway for the new 33's.... I'll just figure it out as I go. Maybe this will help someone.
The lift is the DPG 5" lift that actually netted 5". The tires are 33 x 12.50. I wanted to cut so that there would be a lip left on the front and rear fenders (like a mini flare). I had no intentions on re-attaching the plastic flares, but I wanted to make it look as clean as possible. Some folks cut to the top of the old plastic flare line, some cut to the top of the ridge that I left on the fender. I didn't need to cut that much.
First thing I discovered was that a Dremmel (while precise) is slow. I went through a dozen wheels on one front fender. Inside the front well, it really looks better without the rubber liner. There is a seam inside that I banged flat with the 3lb like I had read in other posts.
I finally see that a flippin pool noodle really is probably the best solution to keeping crud out of your doors.
Another thing that I missed in my reading was that you are cutting two layers of metal in the rear (even if you don't cut above the pinch welds. It's thick and takes a serious tool (read: Not a Dremmel) I decided to cut up to the welds instead of slicing and folding. I didn't gain as much space that way, but I didn't need that much in the rear. It will also allow me to put some kind of trim or Mastic Tape on there to clean it up.
The front. The very front corner (marked) will be cut and rounded off to match up better with the bumper.
The rear. Hopefully the trim pieces will be wide enough to cover the half holes.
Here you can see the flared out part of the fenders that I left. The 33's shouldn't rub at all. If they do... the hockey pucks are standing by.
Old December 14th, 2005, 22:05
goodburbon's Avatar
goodburbon goodburbon is offline
Re: Fender Cutting Questions Answered (at least mine)
instead of a dremel, my tool of choice was a pneumatic cut off tool. I made fast work (30 min) of the front fenders and they came out very clean and very easy
Old December 14th, 2005, 22:25
offroadman83's Avatar
offroadman83 offroadman83 is offline
You will probably find out you will need more trimming in the front. I have figured out with my setup that it would be perfect to trim to the jutted out line on the body but I haven't yet----------Kyle
Old December 14th, 2005, 22:30
XJ Un-Limited's Avatar
XJ Un-Limited XJ Un-Limited is offline
If you have access to air tools, a die grinder with a cut off wheel works well for the front fenders. At least it did for me, a 3" reinforced wheel last for one and a half fenders. For the back, the cut every inch or so with a sawsall or scrollsaw and bend with a hammer worked. A little flat black trim and it looks rather clean.
Old December 15th, 2005, 10:12
JIMBOJAMES's Avatar
JIMBOJAMES JIMBOJAMES is offline
Even with all that trimming you will still probably need at least one or two hockey puck bumpstops. My 4.5" lift I am running 3 hockey pucks and I have cut fenders.
Old December 15th, 2005, 10:45
XTrmXJ's Avatar
XTrmXJ XTrmXJ is offline
Dam just take the tire and lift it up to the fender and draw an outline of it, then cut with a jigsaw and be done with it, its a perfect match for the tire
Welder QUestions Kejtar Tow Rigs and Trailers 10 June 11th, 2007 09:11
plastic trim after fender cutting...where to get and the cheapest? XJ4Roks Modified Tech Discussion 4 March 11th, 2005 23:58
R&R original fender flairs . . . '88XJ Don Becker OEM Tech Discussion 2 January 31st, 2005 10:31
Fender Cutting Help W/ Pictures lickdj Modified Tech Discussion 6 December 21st, 2004 12:31
Fender Trimming Questions? KGNickl Modified Tech Discussion 7 July 17th, 2004 21:25
