Old September 19th, 2005, 11:59
acanfield acanfield is offline
AX5 Rebuild Time?
My 85 XJ 4WD transmission is finally toast, although everything else stock (including 2.8L V-6) is still running strong. Can anyone give me a rough estimate for time and effort to rebuild an AX-5 transmission?
I ordered the AX 4/5 Transmission Repair Manual and hope that will give me a rough idea. It sounds and feels like at least 2nd and 3rd will need repair, so I could be looking at significant costs.
A rebuilt or used transmission might be in order. Can I assume the an AX-5 from a later-model-year YJ or XJ will match my 2.8L V-6?
Old September 19th, 2005, 15:17
carnuck's Avatar
carnuck carnuck is offline
Re: AX5 Rebuild Time?
Up to '96 will interchange w/o much trouble. Shifter tower changed after that. If it's the input shaft that went bad, you can almost guarantee the countershaft is toasted too. If you can find a Dodge Dakota with 4 cyl 5 speed, you can use that bellhousing/clutch stuff for an AX-15 upgrade.
I'm about to send several 2wd AX-5s for scrap metal as they are too common around here and no-one wanted to buy them for $40 apiece.
Old September 19th, 2005, 21:16
Carnuck, thanks for the reply. All the gears still drive but there is an intermittent screech in 1st through 3rd and sometimes reverse. The parts that came out look like a synchro or snap ring. Perhaps the input shaft is still okay, but hard to say without looking.
The Mantrans.com main plant is just 90 miles away in Tallahassee FL so I might pull the tranny and swap them for a rebuilt.
A salvage yard here actually quoted $650 for a used transmission from a 4 cylinder YJ--the same price of a rebuilt from ManTrans, which comes with a warranty. Not a hard choice there...
Part Time 4wd vs Full time? KiwiXJ OEM Tech Discussion 13 March 6th, 2006 13:21
XJ's 4.0L Hit an all time low. Osprey413 OEM Tech Discussion 29 July 12th, 2005 00:18
Ok going to try this oil pan 1 more time.... 89TrailXJ OEM Tech Discussion 15 August 18th, 2003 06:59
242 not liking 4 high part time skog OEM Tech Discussion 2 July 23rd, 2003 05:45
2.5L Rebuild advise...... Ghost OEM Tech Discussion 7 July 16th, 2003 10:15
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
