Old August 30th, 2005, 13:01
iBran iBran is offline
crank-crank-crank-crank-cra... [wait...] crank-crank-START!
Problem: '94 Cherokee has trouble with cold starts.
* It will crank and crank and crank if you just get in and turn the key. It sounds like it wants to start, but just can't.
* If I let it crank a few times, turn the key back to "run", and then to "start",
-OR-
* If I give it some gas while it's cranking,
it'll start up, but idle really rough, and I have to give it gas to keep it running. After a few revs with the pedal, it's fine.
* If I just turn the key to "run" and leave it there for ~20 seconds before turning it to "start", it usually starts up just fine.
Another clue: This all started after my Jeep was involved in a (minor) rear-end accident. The tank area wasn't damaged; only the driver's-side corner of the rear bumper was hit at ~20 MPH by a Honda Civic as I was slowing down to make a right turn.
I think it's the fuel pump. Maybe things back there got shaken up just enough to cause the pump to go bad? My friend says it could be the regulator and/or filter as well.
Anyways, first question: Where's the regulator?
Question B: Wouldn't the pump make some whining/squealing noise if it were going bad?
III: What else could be wrong? CPS?
Old August 30th, 2005, 15:12
footdale's Avatar
footdale footdale is offline
Re: crank-crank-crank-crank-cra... [wait...] crank-crank-START!
-OR-
I have similar symptoms off and on. I think that it can be classified as a "Jeep thing." The fuel line lose the pressure when it is off, so (as you mention above) leave the ignition in the "run" position until the fuel pump turns off (you'll hear it). I replaced the CPS about a year ago and it still happens to me, maybe less frequent than it used to. I wouldn't worry about it unless it fails to start.
Old August 30th, 2005, 15:13
XgeekstarX's Avatar
XgeekstarX XgeekstarX is offline
that twenty seconds before it starts is your fuel pump building up pressure. with my xj when you cut the key on you can hear it buzz for a second or two as it builds up. yours is probably just shot and is taking a long time to build up pressure to the injectors.
i'd put a new fuel pump in it and while you're under there might as well put a new fuel filter in too.
Old August 30th, 2005, 15:32
dizzymac's Avatar
dizzymac dizzymac is offline
sounds like normal Jeep thing, try turning key to "run" twice then try starting, I NEVER use my gas pedal while cranking. These turn a few revs. b-4 staring anyway, normal.
Old August 30th, 2005, 20:10
Toph Toph is offline
Sounds like a fuel pump on it's way out to me.
Just my .02
Old August 30th, 2005, 22:44
MAP's Avatar
MAP MAP is offline
You need to get a fuel pressure gauge and check the pressure when you experience the symptoms.
Old spark plugs will also give you similar symptoms.
But if this started right after your accident, then the fuel pump does seem like a possibility.
MAP
Old August 31st, 2005, 09:43
rickoregon's Avatar
rickoregon rickoregon is offline
Having been into the fuel tank on our '89 XJ recently I've seen how the 2" transfer hose could easily become dislodged by your 20mph quarter corner impact. Especially if it's getting old.. Or the screen "sock" filter that connects to the fuel pump inside the tank may have become dislodged allowing junk from the tank (and the outside of the sock filter) to go inside your pump, partially plugging the pump and/or fuel filter. Of course, this possibility assumes the fuel system on your '94 is the same as on my '89, and that I don't know.. The pressure test that MAP suggested would give you a clue. Hope this helps. Later, Rick
Rick & Kate Johnson
Venice Ranch, Burns, Oregon 97720
http://home.centurytel.net/venice/
Old August 31st, 2005, 14:54
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
Just my .02
Could be, but not necessarily. The check valve can go long before the pump itself. Mine has been doing it for the last 100 thousand miles or so (245k on the original pump). I just wait before I crank. My other car is a diesel, so I'm in the habit anyway.
Old September 1st, 2005, 11:33
jlex jlex is offline
On my '98 there's a check valve on the fuel pump & on the filter/regulator. Someone posted that if they go bad, you can get an in-line check valve to keep the pressure in the line for the next startup. May want to search check valve. I think they said they used a BMW in line check valve.
jlex.
Old September 15th, 2005, 14:39
Mestopin Mestopin is offline
Here's the part number
"The BMW fuel check valve part number 16 14 9 068 988
This is the part number I used to purchase the valve from Momentum BMW in Houston. Someone from JU said their BMW delaer couldn't find the part with this number.
Also, I paid $2.67 but I believe the price has gone up some.
Here's the link with some pictures from the JU writeup
http://www.jeepsunlimited.com/forums...ght=long+crank
By the way, it's been almost 4 months now and I still crank almost immediately (1/2-1 second).
Mark
91 XJ 126k
Old September 17th, 2005, 17:55
KingA KingA is offline
I had problems starting my 87 that were similar to that. The distributer needed to be re-indexed. Solved the problem..
Old October 9th, 2005, 08:29
kawijames's Avatar
kawijames kawijames is offline
replace the fuel pump and regulator as a pair. my 91 had the same issues as you are describing. after checking my FP i found that initially i had 5 psi but after 15-20 seconds the pressure had increased significantly. remember that when your pump is on its way out many times( not always) this puts strain on the diaphragm in the FPR. just helpful advice
Old October 18th, 2005, 22:12
My buddy is available this Friday to help me replace the pump.
Anyone have some tips/pointers to make this thing go smoothly? I've never done a fuel pump, let alone drop the tank. He's helped somebody put a new pump in a ZJ, which I would assume is the same.
One question:
- Autozone has two pumps available, a "short style" and a "long style".
Anyone know what "style" a 1994 with the 4.0L would have?
I'll probably go to Napa, but just wanna be prepared in case they ask the same question.
And yeah, we'll definitely do the filter and probably the regulator as well.
Old October 19th, 2005, 22:20
Bump! If nobody has anything else to say, I'm gonna assume this thing is gonna be a piece of cake. Hope so!
Old October 20th, 2005, 15:33
Alienspecimen Alienspecimen is offline
Wait...
I have something to say.
I think that your tip about being rearended gave it away and this might stop this nasty "Jeep thing" rumors.
I had longer starting times recently. It started after my hanger on the back, right where the muffler is rusted out and the whole back end of the exhaust was not supported and was vibrating slightly. Fixed it and that fixed my problem.
Apparently loose exhaust system can cause longer starting times.
Boris
wont crank wont start nothing 90xjpos OEM Tech Discussion 13 February 6th, 2007 11:52
XJ will crank but wont start :( BiggJohnson06 OEM Tech Discussion 2 May 21st, 2005 02:58
No crank - no start Phil OEM Tech Discussion 2 April 20th, 2005 18:16
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
