Old August 24th, 2005, 13:57
slvr98svt slvr98svt is offline
D44 Knuckle Rotation Question
Hey I am about to rotate my pinion and knuckles. However I am not sure where to rotate from. It is a low pinion and everyone says anywhere from 11-13 degrees. It is going to be a DD with around 8" of lift, I was wondering if you rotate the pinion from stock location up 11 degrees or from the pinion being at 0 degrees horizontal, then up 11. I figured I would go eleven and my castor at 6 that way I can adjust the the pinion a little with the control arms.
Thanks Aton,
-Matt
Old August 25th, 2005, 01:13
Israel's Avatar
Israel Israel is offline
Re: D44 Knuckle Rotation Question
In my opinion it sounds like you'll need a lot more pinion angle if you've got a low pinion axle and will be running 8" of lift. Your caster should work just fine at 6 degrees.
Read Crash's Dana 44 article. It will answer all of these questions plus answer a lot more you haven't thought of yet.
Old August 25th, 2005, 01:55
BrettM's Avatar
BrettM BrettM is offline
I rotated my Waggy D44 16 degrees from stock (7" lift), it's farther than ideal, I would go for 12-14 degrees from where they started. caster at 6 works great for me.
Old August 25th, 2005, 04:57
Ok thanks. I have read through the article many times, just forgot that it had mentioned from horizontal in there. So I did get the answer to my question. It is going to be a DD and after getting it up on my jig and everything 11 just didnt look like enough. I planned on going up another degree or two, so I will probably end up with 13. I just hope that its not to much.
Thanks,
-Matt
Old August 25th, 2005, 09:03
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: D44 Knuckle Rotation Question
when i made my d44, i set the pinon angle at 13* and castor at 6*
i measured the angle on my front driveshaft with the d30 in there, came up with 12*, but my DS was pointed a little low - so 13 it was...
13 above horizontal, and castor was 6* back from vertical...
rides like a dream.
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old August 25th, 2005, 09:09
Jeepin Jason's Avatar
Jeepin Jason Jeepin Jason is offline
NAXJA Member #1100
FWIW, I ran a Waggy 44 front end for 2 years, with the knuckles/pinion at the stock angles, and never had any troubles that I could attribute to the pinion angle. I don't run big rocks like you find out west, so clearance really wasn't much of an issue though.
Old August 25th, 2005, 15:47
tealcherokee's Avatar
tealcherokee tealcherokee is offline
im leaving mine at stock angles....
Old August 25th, 2005, 16:03
Yeah I understand, however I have my knuckles already off the tubes so its no big deal to me anyway, especially since I work at a race car fab shop. So the welding is nothing to my boss, hes willing to help me out in any way.
-Matt
D44 Brake Line question old_man Modified Tech Discussion 12 June 1st, 2005 10:48
RE bracket kit for D44 front - UCA bushing question Capt. Nemo Modified Tech Discussion 28 April 4th, 2005 14:14
78 Ford f-250 HP d44 axle swap question Haggard Modified Tech Discussion 18 November 12th, 2004 13:59
'79 ford D44 Tie-rod question Fryphax Modified Tech Discussion 9 August 21st, 2004 00:29
Another d44 question h.curtis Modified Tech Discussion 26 October 24th, 2003 10:04
