Old August 24th, 2005, 02:53
mgreen84's Avatar
mgreen84 mgreen84 is offline
Exhaust Mount Brackets
anyone have trouble with breaking exhaust brackets?
Old August 24th, 2005, 08:17
willyb's Avatar
willyb willyb is offline
Re: Exhaust Mount Brackets
Which bracket?? Is it soild mounted?? You gotta have some kind of asorbing material [ie: rubber] so the exhaust is free to move... If you simply weld a hanger from the exhaust to the frame it'll break every time....
Will.
Old August 24th, 2005, 09:46
xjguy98's Avatar
xjguy98 xjguy98 is offline
my rear bracket (the one just to the right of the gas tank) broke last month but it broke in such a way that I could just bend the rest up and re-install the exhaust clamp. Apparently a few years ago, a TSB came out calling for the replacement of the rear mount to the rubber style. Like was mentioned before, metal on metal = bad. metal on rubber = good.
Magnaflow Exhaust Installed Rand McNally Jeep Street and Performance 6 June 20th, 2005 06:07
PA exhaust legislation bill = BAD JU-JU!!! sidriptide North Atlantic Chapter 6 April 18th, 2005 19:38
Anyone running the M.O.R.E. poly trans mount? stoneattic Modified Tech Discussion 1 March 1st, 2004 17:59
Hi-Lift Mount. Wayne Sihler Modified Tech Discussion 2 December 13th, 2003 01:40
XJ/MJ Tow Hook Brackets and Control Arms Ohio Comanchero For Sale: Private Party Only. XJ ITEMS ONLY 3 December 10th, 2003 13:18
