Old August 10th, 2005, 17:31
Elohim1 Elohim1 is offline
Will a tire designed for a 10" wheel fit a 8.25"???
I have some 16.5" x 8.25" wheels. I am wanting to use 42" SS IROK tires. Their web site says to use a 10" width wheel.
Will an 8.25" wheel work fine? If not, Why not?
Thanks
Old August 10th, 2005, 18:42
langer1's Avatar
langer1 langer1 is offline
Re: Will a tire designed for a 10" wheel fit a 8.25"???
Off road 8.25 should work fine. On the highway though the side walls will be pulled in and the tread will not be in full contact with the road, it could be real bad on even a slight turn at even 50mph.
Wheel and Tire Question Dan1990XJ OEM Tech Discussion 6 August 29th, 2004 19:32
wheel and tire question bac XJ Modified Tech Discussion 7 August 25th, 2004 08:17
tire balancing for those who wheel lankchevy Modified Tech Discussion 30 August 18th, 2004 16:39
It's Now Official! (Meet/Greet Date & Time ACE Intermountain Chapter 37 December 9th, 2003 15:48
96 headlights and hardware fit a 87? mark268 OEM Tech Discussion 3 December 7th, 2003 15:43
