Old July 11th, 2005, 20:40
jims89 jims89 is offline
solenoid
What does the solenoid farthest forward in an AW-4 tranny control. My old tranny would not move very well, felt like the parking brake was on when I tried to take off. Everything else worked well and I could even get up to speed and maintain it by manually shifting up as needed. The tranny shop said the forward clutches were bad, or at least the clutch used in D. I replaced the tranny with one from a junkyard. The solenoid closest to the front had been damaged during removal. The connector was broken when the person removing the tranny tried to pull the harness out. I took the one from my old tranny because the connector was still good. now the replaced tranny has the same problem. Did I transfer my problem with the old solenoid or is the tranny hosed from the get go. Thanks
JimP
ARB solenoid fitting? Mike L Modified Tech Discussion 3 February 26th, 2005 12:56
Winch solenoid failure… Bent Modified Tech Discussion 1 February 3rd, 2005 09:14
Transmission & Solenoid BSD OEM Tech Discussion 4 September 26th, 2004 13:15
AW4 solenoid help please earthtiger OEM Tech Discussion 4 August 11th, 2004 18:38
Wanted: Starter Solenoid (CT) Eagle Wanted: Private Party Only 2 March 11th, 2004 05:49
