Old June 5th, 2005, 04:13
Gojeep's Avatar
Gojeep Gojeep is offline
Door hinge repair write up
Just thought I would let you know that I have written a write up on my site for repairing the common door hinge cracking problem.
If anyone should ever need it it is under the body mods section of my site.
www.go.jeep-xj.info
Old June 5th, 2005, 04:28
Ramsey's Avatar
Ramsey Ramsey is offline
Re: Door hinge repair write up
if only i knew how to prevent that 3 years ago before my door fell off in the school parking lot
Old June 5th, 2005, 04:33
Gojeep's Avatar
Wow, that is letting it go all the way! How did you repair that then as would have been a lot harder?
Old June 5th, 2005, 04:42
Ramsey's Avatar
i had it welded at a shop, and it worked well for another 6 months until i sold it. of course if i had known about this site, or anything about xjs i might not have let it go that far.
Old June 5th, 2005, 14:28
dan89XJ's Avatar
dan89XJ dan89XJ is offline
Thumbs up Re: Door hinge repair write up
Gojeep: great write up ! I have the same problem.. but I dont know how bad it is.
When you talk about the thicker panel behind the A pillar, this panel I need to not weld to ? why ?
Also, should I try to push back the A pillar panel back to the original place if it is torn, before welding ?
Dan
Old June 5th, 2005, 14:55
Roll-over Roll-over is offline
Yet another great write-up, Marcus!
-r0
(ps-Thanks for the write-up on raising the rear shock mounts)
Old June 6th, 2005, 01:16
Gojeep's Avatar
Dan
I have added some extra comments clearing up what you are asking. The panel covering most of the A piullar is very thin and holds no strength for the hinge. That panel is already cut away from the factory around the hinge so you dont have to do it, but just make sure you are not welding on it thats all. You should try and knock back the hinge in the correct place before welding but think you will need to remove the front panel to do that.
Thanks for the other comments to guys.
Old June 6th, 2005, 01:29
Huerito Huerito is offline
Red face Re: Door hinge repair write up
It is 12:30 AM and I just ocurred to me that I should post a question about my broken passenger door hinge..
How ironic
Old June 6th, 2005, 01:33
Gojeep's Avatar
Good timing then I nearly didn't post that i had done the write up so glad I did now. It is only 5.38PM here Monday.
Old June 6th, 2005, 21:27
dan89XJ's Avatar
Gojeep: Thanks for the clarification I understand now.. this thin outter panel is cut around where the hinge is welded on the thicker panel inside. I see it now in the pictures.
If I ever get around to it, I'm gonna fix my hinges using your method. Hopefully that'll be before a door falls off :P
Apexi SAFC 2 Write Up!!! MrShoeBoy Modified Tech Discussion 74 March 11th, 2012 20:00
New snorkel write up Gojeep Modified Tech Discussion 38 March 8th, 2007 00:44
rust repair nfldXJ OEM Tech Discussion 6 February 4th, 2005 14:21
help. write up ? generalleexj Modified Tech Discussion 0 January 14th, 2005 20:02
Steering adjustment write up XJ_ranger Modified Tech Discussion 5 November 12th, 2004 17:12
