Old May 28th, 2005, 19:50
Jeep 250's Avatar
Jeep 250 Jeep 250 is offline
Question What dose as stock dana 44 look like
I was at the local u-pull it and think I found an dana 44 in a 94 XJ. Is this possable? It is kinda round but octagon. Looks bigger around than the 35. Is their some way that I can ckeck the vin id? The last time I bought an compleat frount end it cost my $150. Is this worth looking into?
Dennis
Old May 28th, 2005, 19:58
cherowagon's Avatar
cherowagon cherowagon is offline
Re: What dose as stock dana 44 look like
does it have two little ears sticking down? i say 8.25
Old May 28th, 2005, 20:01
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
http://www.yuccaman.com/jeep/gear1.html#axle
Old May 28th, 2005, 20:10
xjoe's Avatar
xjoe xjoe is offline
Here is my xj 44 to the best of my knowledge they only put 44's in 87-89, Very unlikely to see one in a 94 unless it was swapped in...
Old May 28th, 2005, 20:13
ROBZ95Xj's Avatar
Heres a pic of the 44 I swapped into my 95
Old May 28th, 2005, 20:53
Jeep 250's Avatar
Red face Re: What does a stock dana 44 look like?
From looking at the threads, this one (http://www.yuccaman.com/jeep/gear1.html#axle)
tells me that it is an Chrysler 8.25" Is this worth $150? It looks like it will bult right up. My axles are 3.07. I guess is this better than my dana 35?
Thanks for you info, Dennis
Old May 28th, 2005, 22:20
bretto bretto is offline
It will most likely have 3.55 gears. Are you sure you have 3.07 gears? What year is yours and what drive train?
Brett
Old May 28th, 2005, 22:25
johnnyc's Avatar
johnnyc johnnyc is offline
Since it's from a 94, it is a 27-spline 8.25, which may not be worth it. The 29-spline 8.25 is more desirable.
Old May 29th, 2005, 00:27
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
You can find the 29-spline in late-96 and later XJs. Glad the pics helped; and thanks for the plug rob.
Updated jeep parts for sale Lots of after market and stock stuff 96xjeeper For Sale: Private Party Only. XJ ITEMS ONLY 13 February 23rd, 2007 19:46
many stock parts generalleexj For Sale: Private Party Only. XJ ITEMS ONLY 2 December 31st, 2004 17:49
Dana 30/35 (kinda long) 96xjeeper OEM Tech Discussion 14 February 8th, 2004 15:35
Stock and Lift Parts lobsterdmb For Sale: Private Party Only. XJ ITEMS ONLY 4 November 9th, 2003 10:09
Dutchman Shafts are junk...... PeterBuilt North Atlantic Chapter 4 September 4th, 2002 07:28
