Old May 25th, 2005, 16:39
043500 043500 is offline
Possible AX-5 trans issues??
FInally have my MJ running and partially driveable (need shocks and to finish the brakes) but am having some serious noises that I think are coming from the transmission.
It's an AX-5. It is making a rather loud clack-clack-clack sound. Today it popped out of reverse and at one point actually locked up for a few seconds bring the entire jeep to a halt. It did begin moving again almost as quickly as it stopped.
At any rate I am fairly certain it's the tranny...does anyone know what might be happening?
If you think it may not be the tranny feel free to post your thoughts please.
THANKS!
Old May 25th, 2005, 18:20
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Re: Possible AX-5 trans issues??
It sounds like the tranny. I don't think reverse is synchronized, so more likely you have a busted gear or two. Not worth rebuilding. It happens that I just came across some notes I took over a year ago of the dealer prices for AX-5 synchronizers (didn't even get to bearings or -- God forbid -- gears). You don't want to know what the prices were.
Fire up www.car-part.com and see what's available in junkyards near you.
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Trans Question bzdel2441 OEM Tech Discussion 1 May 20th, 2005 10:29
2.5 with AW4 trans Stukboy Modified Tech Discussion 6 March 15th, 2005 11:39
Different trans mounts for 89 5spd? 5.0 Junkie OEM Tech Discussion 3 December 13th, 2004 11:48
Trans leak??? 96country OEM Tech Discussion 14 December 10th, 2003 11:32
Posting image issues? Ralph User Support, Questions and Suggestions 10 December 8th, 2003 07:36
