Old May 16th, 2005, 16:00
olivedrabcj7's Avatar
olivedrabcj7 olivedrabcj7 is offline
NAXJA Member #1384
death wobble (yes ive searched....alot)
i have a 97 cherokee with a 6.5" lift and drop brackets from rubicon express. im running 36x12.50 Tsl's (non radial). on its maiden voyage i had death wobble every time i hit 30 mph. so i had an alignment. now i have it at about 40 mph. so i had the tires balanced. each tire took AT LEAST 28 ounces EACH!! but im still getting the wobble at 40 mph. the alignment shop went through and checked everything under the front end and they said nothing was worn out. everything is tight under there. the guy that balanced my tires did say that "they werent round". the wobble isnt initiated by bumps....it has something to do with speed. everything ive searched says trackbar is loose, or alignment is wrong, or tires are out of balance. i need more suggestions!!! this is pissing me off!!
edit: Also, i dont have a steering stabilizer but from what ive read, a steering stabilizer wont prevent death wobble will it
Old May 16th, 2005, 16:27
jeepinxj05's Avatar
jeepinxj05 jeepinxj05 is offline
Re: death wobble (yes ive searched....alot)
My money's on tires. Bi Ply, right? I've heard they're impossible to balance. Try that dyno bead stuff in the tire. Here's a link to that discussion.
http://www.naxja.org/forum/showthread.php?t=56486
Old May 16th, 2005, 16:30
hologram's Avatar
hologram hologram is offline
Have you checked the stabilizer shock? That was all that was wrong for me. Just a thought.
Old May 16th, 2005, 16:36
Rev Den Rev Den is offline
A steering stabilizer will NOT cause or solve DW...it will only cover it up.
Rev
Old May 16th, 2005, 16:38
NAXJA Member #1384
well if covering it up means my jeep wont slam my steering wheel from lock to lock when i hit 40 mph then it sounds like i need to get a new one!!
Old May 16th, 2005, 16:46
hologram's Avatar
Mine was not at a certain speed, Just when I hit bumps at over 40mph.
and it helped me not to kill everyone on the freeway at 70 mph, trying to get off the road.
Old May 16th, 2005, 16:57
NAXJA Member #1384
well i sold off my stock tires and wheels otherwise id put them on and run down the road looking like a monster truck fresh out of the trailer. i read something about how coil sprung suspensions have a resonant frequency they hit which can cause the wobble. this sounds pretty close to me because i can tell when its about to happen. i get the slightest shimmy in the wheel then as i start braking no matter what i do it gets worse and worse until i am holding the wheel for my life trying not to hit other cars until it stops when i get to a creep...
i just wonder if the steering stabilizer would keep that resonant frequency higher and or stop death wobble before it has a chance to start.
im going to hook up the stabilizer and if that doesnt help ill be looking for some 35" BFG's or MTR's to run on the street.
if anybody has any experiences like im describing please post up!!!
Old May 16th, 2005, 16:58
CRASH's Avatar
CRASH CRASH is offline
At 6.5" of lift your steering angles and Panhard angles are very bad. Get a Tera or other knuckle with a raised draglink position and adjust your Panhard mount accordingly and you will fix your problem.
CRASH
Old May 17th, 2005, 14:07
NAXJA Member #1384
well the steering stabilizer didnt help anything. ive determined its my tires. they seem to be "flat spotted" and im 99% positive thats whats setting off the death wobble. granted...the stabilizer DID help control it once it started.
im gonna go looking for some 35" muds locally. maybe i can trade my swampers for some good shape used mudders.
Bonafied death wobble! 4DLVOFJEEPS Modified Tech Discussion 9 February 4th, 2005 12:25
How I ended my Death Wobble + tires for sale PC-UT-XJ Modified Tech Discussion 0 June 23rd, 2004 15:52
Death wobble Q's XJEEPER04 OEM Tech Discussion 28 August 18th, 2003 17:47
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
