Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old 04-16-2005
goodburbon's Avatar
goodburbon goodburbon is offline
Resident PITA
Lightbulb code OBDII OBD check engine
I have made this thread findable in a search, since I was unable to turn up a comprehensive list of codes in a search.
So, before outlining the proceedure (a.k.a. "key trick") to get the codes, a few things to note:
1) You may have to set the parking brake for the codes to show
2) On older models, the blink-spacing is not always perfectly uniform, so if you see 23 23, it's probably just a single 55 since codes are not repeated (55 is end of codes - it's normal)
3) On newer models with a digital odometer, the codes are usually displayed on the odometer rather than blinking the check engine light.
4) When the computer indicates major failure, it can activate "Limp In" mode, which guesses about data to compensate for sensor failure, allowing you to get the car to a mechanic. One major symptom of this is losing third and/or fourth gear on autos.
The "Key Tricks"
Older (OBDI) models - Start with the ignition off. Within five seconds, switch the key on, off, on, off, on. ("On" is NOT "Start" and "Off" is NOT "Lock"). The "check engine" light will flash. Count the flashes. Each code is a two digit code, so a (for example) 23 would be FLASH FLASH (pause) FLASH FLASH FLASH (long pause). It will never flash more than 9 times, so watch for those pauses!
Newer (OBDII) models - Put the key into the ignition, push down the odometer reset button, then turn the key to RUN with your finger on the button - and then release the button. The odometer will go through 1111111 through 999999, then display the car's serial number. It will then show the error codes (it might show them starting with P). If this method does not work, try the OBDI method.
Older Model Computer Codes (OBDI) - IMPORTANT! Codes may be different for newer vehicles starting circa 1996.
11 No ignition reference signal detected during cranking OR timing belt skipped one or more teeth; OR loss of either camshaft or crankshaft position sensor.
12 Battery or computer recently disconnected
13 MAP sensor or vacuum line may not be working
14 MAP sensor voltage below .16V or over 4.96V
15 No speed/distance sensor signal
16 Loss of battery voltage detected with engine running
17 Engine stays cool too long (bad thermostat or coolant sensor?)
OR
17 (1985 turbo only): knock sensor circuit
21 Oxygen sensor signal doesn't change (stays at 4.3-4.5V). Probably bad oxygen sensor
22 Coolant sensor signal out of range - May have been disconnected to set timing
23 Incoming air temperature sensor may be bad
24 Throttle position sensor over 4.96V
25 Automatic Idle Speed (AIS) motor driver circuit shorted or target idle not reached
26 Peak injector circuit voltage has not been reached (need to check computer signals, voltage reg, injectors)
27 Injector circuit isn't switching when it's told to (TBI)
OR (MPI) injector circuit #1 not switching right
OR (turbo) injector circuit #2 not switching right
OR (all 1990-) injector output driver not responding
- check computer, connections
31 Bad evaporator purge solenoid circuit or driver
32 (1984 only) power loss/limited lamp or circuit
OR
32 EGR gases not working (1988) - check vacuum, valve
OR
32 (1990-92) computer didn't see change in air/'fuel ratio when EGR activated - check valve, vacuum lines, and EGR electrical
33 Air conditioning clutch relay circuit open or shorted (may be in the wide-open-throttle cutoff circuit or normal on early 80's models if you don't have air conditioning)
34 (1984-86) EGR solenoid circuit shorted or open
OR
34 (1987-1991) speed control shorted or open
35 Cooling fan relay circuit open or shorted
OR
35 idle switch motor fault - check connections
36 (turbo only) Wastegate control circuit open or shorted
37 Shift indicator light failure, 5-speed
OR
part throttle lock/unlock solenoid driver circuit (87-89)
OR
solenoid coil circuit (85-87 Turbo only)
OR
Trans temperature sensor voltage low (1995 and on)
41 Alternator field control circuit open or shorted
42 Automatic shutdown relay circuit open or shorted
OR
42 Fuel pump relay control circuit
OR
42 Fuel level unit - no change over miles
OR
42 Z1 voltage missing when autoshutdown circuit energized (The Z1 voltage is the voltage of the circuits fed by the autoshutdown relay. This typically includes fuel pump and switched-battery feed to the ignition coil)
43 Peak primary coil current not achieved with max dwell time
OR
43 Cylinder misfire
OR
43 Problem in power module to logic module interface
44 No FJ2 voltage present at logic board
OR
44 Logic module self-diagnostics indicate problem
OR
44 Battery temperature out of range
45 Turbo boost limit exceeded (engine was shut down by logic module)
46 Battery voltage too high during charging or charging system voltage too low
47 Battery voltage too low and alternator output too low
51 Oxygen sensor stuck at lean position (this may be tripped by a bad MAP sensor system causing a rich condition. If you get hot rough idle and stalling, especially on deceleration, accompanied by flooded engine and difficulty restarting, that can be a bad MAP sensor causing the O2 sensor to try to compensate. If you get poor cold driveability, stumbling and bucking, and acceptable warm driving with poor gas mileage (a drop of 10 mpg or more), that is usually the O2 sensor.
OR
51 Internal logic module fault ('84 turbo only).
52 Oxygen sensor stuck at rich position
OR
52 Internal logic module fault ('84 turbo only)
53 Logic module internal problem
54 No sync pickup signal during engine rotation (turbo only)
OR
54 Internal logic module fault ('84 turbo only) - or camshaft sensor/distributor timing
55 End of codes
61 "Baro" sensor open or shorted
62 EMR mileage cannot be stored in EEPROM
62 PCM failure SRI mile not stored
63 Controller cannot write to EEPROM
64 Catalytic converter efficiency failure
65 Power steering switch failure
Newer model Computer codes (OBDII)
30 Sensor heater relay problem
36 Sensor heater relay problem
106 MAP sensor voltage out of range detected at startup
107 MAP sensor voltage too low
108 MAP sensor voltage too high
112 Intake air temperature sensor voltage low
113 Intake air (charge) temperature sensor voltage high
116 Coolant temparature sensor reading doesn't make sense
117 Engine coolant temperature sensor voltage low
118 Engine coolant temperature sensor voltage high
121 Throttle position sensor and MAP sensor disagree with each other
122 Throttle position sensor voltage low
123 Throttle position sensor voltage high
125 Taking too long to reach proper operating temparature and switch to energy-efficient mode
130 Sensor heater relay problem
131 Oxygen sensor seems to be shorted out or broken
147 Oxygen sensor heater element not working properly (this device helps to reduce emissions more quickly)
151 Oxygen sensor voltage problem - short circuit to ground?
152 Oxygen sensor voltage problem - short circuit to active 12V?
153 Oxygen sensor response too slow
154 Oxygen sensor does not show either a rich or lean condition - may need replacement
155 Oxygen sensor heater element not working properly (this device helps to reduce emissions more quickly)
157 Oxygen sensor voltage problem - short circuit to ground?
158 Oxygen sensor voltage problem - short circuit to active 12V?
159 Oxygen sensor response too slow
160 Oxygen sensor does not show either a rich or lean condition - may need replacement
161 Oxygen sensor heater element not working properly (this device helps to reduce emissions more quickly)
171 The oxygen sensor is saying that the system air/fuel mix is far too lean (too much fuel is being added as a correction).
172 The oxygen sensor is saying that the system air/fuel mix is far too rich (too much air is being added as a correction).
174 The oxygen sensor is saying that the system air/fuel mix is far too lean (too much fuel is being added as a correction).
175 The oxygen sensor is saying that the system air/fuel mix is far too rich (too much air is being added as a correction).
176 Flex fuel sensor can't be seen
178 Flex fuel sensor problem
179 Flex fuel sensor problem
182 Compressed natural gas temperature sensor problem
183 Compressed natural gas temperature sensor problem
201 Injector #1 control circuit problem (open or shorted)
202 Injector #2 control circuit problem (open or shorted)
203 Injector #3 control circuit problem (open or shorted)
204 Injector #4 control circuit problem (open or shorted)
205 Injector #5 control circuit problem (open or shorted)
206 Injector #6 control circuit problem (open or shorted)
207 Injector #7 control circuit problem (open or shorted)
208 Injector #8 control circuit problem (open or shorted)
300 Misfire detected in multiple cylinders.
301 Misfire detected in cylinder #1.
302 Misfire detected in cylinder #2.
303 Misfire detected in cylinder #3.
304 Misfire detected in cylinder #4.
305 Misfire detected in cylinder #5.
306 Misfire detected in cylinder #6.
307 Misfire detected in cylinder #7
308 Misfire detected in cylinder #8.
320 Crankshaft position sensor reference signal cannot be found while the engine is cranking.
325 Knock sensor (#1) signal is wrong.
330 Knock sensor (#2) signal is wrong.
340 No camshaft signal being received by the computer
350 A coil is drawing too much current.
351 Coil #1 is not reaching peak current at the right time
352 Coil #2 is not reaching peak current at the right time
353 Coil #3 is not reaching peak current at the right time
354 Coil #4 is not reaching peak current at the right time
355 Coil #5 is not reaching peak current at the right time
356 Coil #6 is not reaching peak current at the right time
357 Coil #7 is not reaching peak current at the right time
358 Coil #8 is not reaching peak current at the right time
401 A required change in air/fuel mixture was not detected during diagnostic test.
403 An problem was detected in the EGR solenoid control circuit.
404 The EGR sensor's reported position makes no sense
405 EGR position sensor voltage wrong.
406 EGR position sensor voltage wrong.
412 The secondary air solenoid control circuit seems bad (this is used for the aspirator).
420 The catalyst seems inefficient (#1).
432 The catalyst seems inefficient (#2).
441 Evaporative purge flow system not working properly
442 A leak has been detected in the evaporative system!
443 Evaporative purge flow system solenoid not working properly
455 A large leak has been detected in the evaporative system!
456 A small leak has been detected in the evaporative system!
460 The fuel level sender is not reporting any change over a long distance. Something seems wrong.
461 The fuel level sender is not reporting any change over a long time. Something seems wrong.
462 Fuel level sender voltage wrong.
463 Fuel level sender voltage wrong.
500 Haven't heard from the speed sensor lately.
505 The idle speed air control motor doesn't seem to be working correctly.
522 Oil pressure sensor problems
523 Oil pressure sensor problems
551 The power steering switch may not be working. (Neons: high pressure is showing up at high speed)
600 Oh-oh! The coprocessors aren't talking to each other within the computer!
601 Internal computer error!
604 Internal computer error! (RAM check)
605 Internal computer error! (ROM)
615 Starter relay circuit problem
622 Generator field control problem
645 A/C clutch relay circuit problem.
700 The automatic transmission computer or Aisin computer has a problem - ask it what's going on. I don't know.
703 Brake switch circuit information seems wrong.
711 Based on the transmission temperature and its operations, it looks like the transmission temperature sensor's gone bad.
712 Transmission fluid temperature sensor voltage wrong.
713 Transmission fluid temperature sensor voltage wrong.
720 The Output Shaft Speed Sensor doesn't match the reported vehicle speed.
740 The engine's running faster than it should for these speeds, so I think thetorque convertor clutch lock-up system is bad
743 Torque converter clutch (part throttle unlock) solenoid circuit problem - shift solenoid C electrical fault
748 Governor Pressure Solenoid circuit problem (Transmission relay circuit problem in Jeep RE transmissions)
751 Overdrive override switch has been pressed for over five minutes. Just thought you should know.
753 Overdrive solenoid control circuit problem (transmission relay circuit in Jeep RE transmissions.)
756 Shift solenoid B (2-3) fault
783 The overdrive solenoid can't go from 3rd gear to the overdrive gear.
801 Transmission reverse gear lockout solenoid circuit problem!
833 Problem with the clutch-released switch circuit?
1192 Inlet air temperature sensor voltage is wrong
1193 Inlet air temperature sensor voltage is wrong
1194 Oxygen sensor heater performance is faulty
1195 Oxygen sensor is slow
1196 The oxygen sensor switched too slowly (bank 2).
1197 The oxygen sensor switched too slowly (bank 1).
1198 Radiator coolant temperature sensor voltage is wrong.
1199 Radiator coolant temperature sensor voltage is wrong.
1281 The engine is staying cold too long - check your thermostat.
1282 The fuel pump relay circuit seems to be having a problem.
1288 The intake manifold short runner tuning valve circuit seems to be having a problem.
1289 There's a problem in the manifold tuning valve solenoid control circuit.
1290 Compressed natural gas system pressure is too high
1291 The heated air intake sensor does not seem to be working.
1292 Natural gas pressure sensor issue
1293 Natural gas pressure sensor issue
1294 Can't get to target engine speed, check for vacuum leaks and idle speed motor issues.
1295 The throttle position sensor doesn't seem to be getting enough electricity.
1296 The MAP sensor doesn't seem to be getting enough electricity.
1297 The MAP sensor doesn't change its reading when the engine is running!
1298 During wide-open throttle, the engine runs lean.
1299 MAP Sensor and Throttle Position Sensor signals don't match, check for a vacuum leak.
1388 Auto shutdown relay circuit problems?
1389 No Z1 or Z2 voltage seen by the computer when the auto shutdown relay is used.
1390 Cam and crank signals don't match - did the timing belt skip a tooth?
1391 Sometimes, I can't see the crank or cam sensor signal.
1398 I can see the Crank Sensor's signal when I prepare for Misfire Diagnostics. Try replacing it.
1399 Problem in the Wait to Start Lamp circuit - (diesels only?)
1403 EGR position sensor not getting (enough) voltage.
1476 Too little secondary air injection during aspirator test.
1477 Too much secondary air injection during aspirator test.
1478 Battery temperature sensor voltage wrong.
1479 Transmission fan relay circuit problems?
1480 PCV solenoid circuit problems?
1481 Transmission RPM pulse generator signal for misfire detection seems wrong.
1482 Catalyst temperature sensor circuit shorted low.
1483 Catalyst temperature sensor circuit shorted high.
1484 The catalyst seems to be overheating!
1485 Air injection solenoid circuit problems.
1486 Pinched or blocked hose in the evaporative hose system.
1487 Control circuit of the #2 high-speed radiator fan control relay is having problems.
1488 Auxiliary 5-volt sensor feed is too low.
1489 High speed radiator fan control circuit problem.
1490 Low speed radiator fan control circuit problem.
1491 Radiator fan control circuit problem (may be solid state relays as well as other circuits).
1492 Ambient or battery temperature sensor voltage wrong
1493 Ambient or battery temperature sensor voltage wrong
1494 Leak Detection Pump (LDP) pressure switch problem - electrical or the pump itself.
1495 Leak Detection Pump (LDP) pressure switch problem - the solenoid circuit.
1496 Sensor feed is below an acceptable limit. (under 4v for 4 seconds - should be 5v).
1498 High speed radiator fan control circuit problem. (#3 control relay)
1594 Voltage too high in charging system.
1595 Speed control vacuum or vent solenoid control circuits shorted or lost.
1596 Speed control switch always high
1597 Speed control switch always low
1598 A/C pressure sensor voltage high
1599 A/C pressure sensor voltage low
1681 No messages received from the cluster control module (dashboard computer).
1682 Charging system doesn't seem to be working well. Check alternator, etc.
1683 Speed control servo power control circuit problem.
1684 The battery has been disconnected within the last 50 starts.
1685 Invalid key received from the Smart Key Immobilizer Module.
1686 No messages received from the Smart Key Immobilizer Module.
1687 No messages received from the Mechanical Instrument Cluster module.
1 693 The companion engine control module has shown a fault.
1694 No messages received from the powertrain control module-Aisin transmission.
1695 No messages received from the body control module.
1696 Unsuccessful attempt to write to an EEPROM location!
1697 Unsuccessful attempt to update Service Reminder Indicator (SRI or EMR) mileage!
1698 No messages received from the electronic transmission control module or the Aisin transmission controller.
1719 Transmission 2-3 gear lockout solenoid control circuit problem.
1740 Either the tcc solenoid or overdrive solenoid systems doesn't seem to be making much sense.
1756 Transmission control pressure not equal to target. (Mid pressure problem)
1757 Transmission control pressure not equal to target. (Zero pressure problem)
1762 The Governor Pressure Sensor input was too high or too low for 3 consecutive park/neutral calibrations.
1763 The Governor Pressure Sensor input is too high
1764 The Governor Pressure Sensor input is too low.
1765 Open or short in the Transmission Relay control circuit.
1899 The Park/Neutral switch seems to be stuck!
Old 04-16-2005
casm's Avatar
casm casm is offline
BBQ FTW
Re: code OBDII OBD check engine
Thanks for posting this; it's a useful bit of reference to have in a searchable way. With that said...
This is one of my pet peeves (and it's not your fault - it keeps getting reiterated by a *lot* of people) with how people perceive the OBD-II system on an XJ as reporting its codes. The method outlined above will work on some Chrysler models that were built concurrently with the XJ, but to the best of my knowledge no-one has yet provably made it work on an XJ.
Holding in the trip meter button while turning the key to the 'Run' position has - on every digital-odometer XJ I've seen - simply done the gauge/light test for the instument cluster. No OBD-II codes or the vehicle's serial number have ever come up for me using this method. Similarly, I don't know anyone who has ever provably made the ON-OFF-ON-OFF key trick work on a digital-odometer XJ.
To summarise: if it's an OBD-II XJ, you'll need an OBD-II scan tool to get the codes. I'm willing to admit that there are always exceptions to the rule, but until someone can honestly show either of these methods working in an OBD-II XJ with a stock instrument cluster and computer, I'm calling SPOBI on it.
(And no, I'm not attacking you by any means - just getting tired of seeing the myth perpetuate itself. Until proven otherwise, that's exactly what it is: a myth, not fact.)
2000 Limited - 4.0, NP242 (Tom Woods SYE & driveshaft), AW4, D30/44 (4.10 gears and ECTEDs at both ends), OME 3" HD lift (ACOS & shackles for a total of 4.5"), Teraflex rear discs, JKS UCAs/LCAs, loaded. Proud member of the Heated Seat XJ Association.
Old 04-16-2005
goodburbon's Avatar
Resident PITA
Talking Re: code OBDII OBD check engine
then how did I just read the codes on my 97 xj?
I had to turn the key 3 times, and it posted the codes on the odometer
12
31
55
Old 04-16-2005
casm's Avatar
BBQ FTW
Try this on the ones I've tested with here ('97-'01) and it won't work.
Note that I didn't say it was totally impossible, but we do seem to be getting conflicting reports from people with the same model-year vehicles as to whether or not it's effective.
Do this: try the trip meter button trick and tell me if it reports any OBD-II codes. I'm wondering if some '97s didn't have a different setup to others (which wouldn't surprise me, because Jeep did some funky stuff in that year). It could be that some '97s use software that'll let you get the codes, whereas others don't.
Old 04-16-2005
goodburbon's Avatar
Resident PITA
I did that at first, and all it did was go through the numbers, and make all the gauges and lights go through a diagnostic type sweep
I wouldn't have posted it if it didn't work, sorry if it doesnt work for anyone else
just try inserting the key, turning it to run 3 times, and on the third time leaving it on run. I doesnt do the 1-9 sequencing and it takes a few seconds, but the codes showed
Old 04-17-2005
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
At times, an extra set of OFF-ON may be needed to flash the codes:
ON-OFF-ON-OFF-ON-OFF-ON
If possible, drive the Jeep around for awhile to warm it up and make sure that all sensors are reporting back to the computer.
I also seem to recall hearing that putting the auto tranny in Neutral helped in stubborn cases where the codes wouldn't flash...can't confirm that one though.
Don't forget to do your reading: http://allpar.com/fix/codes.html
Old 04-17-2005
devildog0 devildog0 is offline
Sorry the key trick dosen't work on the OBD II systems. If it is giving you the 2 digit codes then that is not the right codes, the OBD II systems provide a Pxxxx Code. True there will be exceptions to this rule. But with as cheap as the new Actron OBDII handheld scanners are, that just read codes and erase them I would invest in one of those to get the code especially if you own newer vehicles. It will pay for itself it already has for me.
Old 04-17-2005
Atl XJ's Avatar
Atl XJ Atl XJ is offline
I have a '95 so I dont really know but I've read that it does work on 96-98 OBDII XJs. Thats just what I read though.
Old 04-17-2005
RichP's Avatar
RichP RichP is offline
Yea, I bought one of the scan tools at advance auto, cp9135 and have used it on both our jeeps, neighbors jeeps and some other cars. I think it was $150 or so and has a cd with it to seach the codes out of the database... Hand because you can also drive with it if necessary for intermittant codes that go away.
Rich Pierson
member #153 98XJ, 1 97TJ, 1 97ZJ
Go Green, recycle congress and the senate.
Old 04-17-2005
casm's Avatar
BBQ FTW
Yup, tried that one as well. On both my old '01 Sport and current 2000 Limited, it doesn't work - same applies to the '97-'99 vehicles I've tried it on.
That one didn't work either... Nor did setting the handbrake.
I'm guessing that some '97s may have had the ability to flash the codes, but that software changes at some point removed it. It'd be nice to be able to get this definitively sorted out once and for all - it bugs me when inaccuracies get reported along with otherwise-useful information.
Old 04-17-2005
RichP's Avatar
I seem to remember a flash update they did on some 97 and 98 models, it was supposed to eliminate pinging, I wonder if they disabled that feature as part of the 'update'.
Rich Pierson
Old 04-17-2005
goodburbon's Avatar
Resident PITA
Sorry for the misinformation all, it appears that I have been overruled.
but I do not understand how it could throw the "wrong codes"? and why I should invest 150 on a cute little orange box when it tells the same thing as my odometer, which it does, so the little orange boxes must throw the wrong codes too.
I realize that my jeep is a 97 and a transition year for the cherokee. So I will just consider myself lucky that I can do it for free, and spend that money on something more effective, like a SYE.
Old 04-17-2005
RichP's Avatar
We are not busting on you, it's just that this 'key check' thing comes up on a regular basis. I tried it on my 98 and it does NOT do it, tried it on my daughter 97TJ and it does NOT do it. Will try it on my sons 97TJ once we get the nose back on and back together again. My daughters 97 was built in feb 97, my sons was built in sep 96. I would not be suprised if his did it provided it is the same ECU that it left the factory with. Any idea when yours was built, you can plug the VIN number in on the jeep site and it will give you a build sheet that *might* have the month is was born on... Mine did.
It might give us a getter idea of how to pin the cut off point...
Rich Pierson
Old 09-21-2005
goodburbon's Avatar
Resident PITA
I actually had to come back and check this thread, glad I made it findable!
I did some playing around with a few jeeps and the trick worked on several of them. 1995 worked, it just flashed the check engine light for every code. as I said before my 1997 worked, I'll try to pin down the month produced, as suggested by Rich
2000 did NOT work. 2002 did NOT work.
I also noticed that if you took too long to cycle the key it wouldnt work. you have to do it fairly rapidly. i'd say less than 4 seconds for sure.
Old 09-22-2005
bjpembo bjpembo is offline
I have a 5-97 xj and i can retrieve my codes using the flashing check engine light method or by using the digital odometer method. to make the engine light flash i have to turn the key on and off 5 times leaving it on the last time and it will go through the flashes. I can also hold my trip button in and turn the key on and off 3 times leaving it on on the 3rd time and the odometer will go through the digits all 1's 2's 3's and so on till it reaches all 9's also, the gauges will go through their full line of motion as the numbers increase, it will then display the codes, its actually kinda of cool to watch. I discovered i could do this shortly after i purchased my jeep, i began having trouble and suspected a faulty tps sensor and did some searching and found those 2 methods of extracting the codes, and tried both with the same results, I received a code 12 for the battery/computer disconnect, a code 24 for the tps, and a code 55 to signal the end of the codes. I purchased a tps sensor, installed it, and the problem was solved. I also found several places that stated depending on the year of your jeep, one, both, or none of the methods would work.
Hi btw, its my first post 8)
Check Engine light Walt from Ky OEM Tech Discussion 12 05-28-2010 12:16
Idle/Starting problem + engine code help CityRatedXJ OEM Tech Discussion 6 04-26-2005 18:22
check out my blown engine xjfrancis Modified Tech Discussion 48 02-09-2005 10:56
Check engine codes with no engine light rusty1007 OEM Tech Discussion 2 12-18-2004 13:19
Emissions Test and Check Engine Light aplatz OEM Tech Discussion 5 06-03-2004 10:34
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
NAXJA and NAXJA logo's Copyright NAXJA. All content/images Copyright NAXJA 1999-2009
